Results 1 to 8 of 8
Thread: D4 - diff and transfer box fill holes - level with full capacity or measure the fluid
    Feb 2011
    Hobart, Tasmania, Australia
    Question D4 - diff and transfer box fill holes - level with full capacity or measure the fluid
    While looking for the drain and fill plug torque settings I noticed that there's mention in a few of the guides that when refilling the front and rear diff (axel oil) and transfer case oil to measure out the specified capacity and only fill that in, rather than just filling until the oil level reaches the bottom of the fill hole. Are the fill holes therefore not in the correct position relative to the full capacity (i.e. are the fill holes above the level where the oil reaches when filled up to specified capacity)? Seems like an unnecessary complication...
    That is correct - you are supposed to measure the correct amount of oil for the diffs and tfr case and put that in.
    However the amount is close to being the same as filling to the bottom of the fill hole and that is what I now do and have had no issues - there is probably less than and extra 50ml (guessimate) that goes in.
    Nov 2015
    Black Rock
    Just to clarify, the diffs must be filled by volume only. And it is a different volume for each diff and different volume and oil for the (rear) e-diff.
    The transfer case, however, can be filled to the "fill" plug as it is positioned at the correct volume.
    Not sure why this is not the case for the diffs.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Feb 2011
    At that close it seems the lazy way is probably close enough...
    Quote Originally Posted by DieselLSE View Post
    Seems silly not to. Just an added complexity for no extra benefit.
    I wonder how many mL of old fluid/oil remains inside after a drain...
    Brisbane,some of the time.
    My Indie has done thousands over the years,and fills them to the level plug,no issues.
    Dec 2009
    Ranelagh, Tasmania
    My L494 has basically the same diffs and to my surprise the manual says fill until weeping from fill hole.
    Volumes were the same as my old D4.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Sep 2014
    Baldivis WA
    I changed all fluids at Christmas, including front and rear diffs, transfer case,engine oil and coolant.
    i measured the required volumes out for each one after a “drain and wait” (I.e have a coffee while waiting for it to finish dribbling). Would you believe the measured volume that goes in fills to the fill plug and you get a little dribble out...
    so next time, I’ll just fill to the plug and do it the old fashioned way.
    Avoca Beach
    Maybe they are afraid that you will fill it on a 40degree slope.
    Regards Philip A
