Results 1 to 10 of 22
Thread: Second Battery installation
    Jan 2019
    Katherine NT
    Hi guy's .Where is the best place to install second Battery on Disco 3 ?
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Laurie 123 View Post
    2 places to chose from, the factory auxiliary position by he ABS pump or in front of the main battery. I put mine in the auxiliary tray but had to cut a hole in the lid as i used an 85ah AGM instead of a crappy yellow top 55ah.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2013
    Either the rhs near the brake booster/abs unit or buy a mount to put it straight behind the main battery
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    Jun 2010
    Central Coast NSW
    Got a pick of that? I just put in a 55ah yellow top and while in happy with the neatness i do want a bigger battery. I was thinking of putting in a third but the additional cost is putting me off.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Disco-tastic View Post
    Yep.
    1974 VW Kombi bus
    Jul 2016
    Blackstone
    Just putting it out there. Behind the second row of seats. More initial set-up cost. But will fit 2 x100ah batteries if you need more capacity later. Will definitely last longer than in the engine bay and gets the weight low and central. Had my auxiliary behind the air filter but upgraded to 2 x100ah lithium’s behind the second row seats. Working well so far.
    MY08 TDV6 D3 Zermatt Silver, B.A.S ECU Remap, ARB Bar, 12K Kingone Winch, 2x100Ah LiFePo4 Auxiliary Power, Safari Snorkel, Baja Rack Roof Rack, Brown Davis Aux. Tank, RWC, Front Runner Rear Ladder, Drifta Drawers, Doran TPMS, LLAMS, GAP IID BT.
    Jan 2019
    Katherine NT
    Thanks for that mate .I thought about the aux spot but my battery is an 85ah same as yours .Here's me worried about looks but looks ok to me with how you've put yours.The battery i have is fairly big so i will have to do a few adjustment.Cheers.
    DiscoMick Guest
    Another option would be to hide it in drawers in the back
    St Helena,Melbourne
    4.28 MB
    A few options, for me I use the 3rd row seats occasionally and don't want drawers mounted so under bonnet suits me.
    1974 VW Kombi bus
    Queensland
    Hi Laurie, what are you planning on using the D3 dual battery system for?
