Results 1 to 10 of 11
Thread: EGT probe protrusion
    Queensland
    How far in do you stick the probe in the exhaust stream?
    With my Auber in the 120 build I only have it in the stream about 13mm.
    With the VDO I bought for the FC I am working on , the instructions are a bit vague but it looks as if it goes nearly right across to the other side.
    I am a bit wary of that as it looks a bit fragile.
    Found this which made me think my first is not in far enough but I can still get 700 C on it.
    The Sensor Connection EGT Probes Motorsports Sensors and Gauges content/not-inserting-egt-probe-tip-completely-center-exhaust-stream-can-result-low-egt-temperature-
    Does this mean my EGT is really higher and I should put it in further?
    What have others done? This is pre-turbo.
    Keith
    Mar 2007
    Canada
    Tip in the center.
    Hay Point
    Won't really matter how deep Keith, as long as it is in the pipe.
    Cheers......Brian
    1985 110 V8 County
    depending on the probe (and its conductivity to the exhaust manifold) you only need to go about 1/8-1/4 of the way into the stream.
    if you get too close to the pipe it will pick up some residual heat from the metal work, its easy to spot when this happens you'll get a normal initial rise a quickish drop but then it will hold for a little while before dropping down slowly.
    IF you're too far towards the outside you'll get a slow rise as the probe bleeds heat to the pipework.
    its not super critical.
    Jun 2013
    Universe A
    Hope this ain't a hijack... But rather general advice question,
    how far would a probe need to go in on a 300 tdi through the egr blank?
    From memory it's some way to get in to the gas flow.
    Queensland
    Quote Originally Posted by Bearman View Post
    Thats what I thought but that article I linked started to make me think otherwise.
    Hay Point
    Quote Originally Posted by 123rover50 View Post
    I have real doubts that would be true. I can believe there might be a few degrees difference between the edge and the centre of the airflow but I wouldn't expect much variance under load. I notice they didn't actually say what the temperature reading were after moving the probe deeper.
    Cheers......Brian
    1985 110 V8 County
    Quote Originally Posted by shack View Post
    About 2 inches.
    as Im stripping my manifold out later this week I'll measure mine for you.
    flick me a reminder.
    Jun 2013
    Universe A
    About 2 inches.
    So any further on this Dave?
    Cheers...
    Cheers...
    yes,
    the probe I have setup for tdi300 has a 90 degree bend which lives outside the sealing compression coupling.
    From the face of the thread of the compression coupling that sits on the manifold flange the probe tip is inserted ~40mm.
    Hopefully I can still ASCII ART....
    ....|.......40mm
    ....|....... ___
    ....|.......V....V
    ....L----=I=---
