Results 1 to 8 of 8
Thread: Puma 2.2 Fuel Rail Pressure?
    Aug 2017
    Rover
    Puma 2.2 engine clatter is noticeably louder after 96,000km
    Hence seeking advice re fuel rail pressure...what should it be?
    at idle?
    at 100 kmhr / 2200rpm?
    Jun 2007
    Margaret River
    Quote Originally Posted by Zeros View Post
    at idle?
    I will set up my ultra gauge to read rail pressure and let you know what my 2.2 reads, later today
    Kingston, Tassie, OZ.
    At idle, low 20s.. I would be running some CRD cleaner/ lube through the tank, or even 200mls of non synthetic 2 stroke oil. Also worth a pilot relearn after 96k.
    Jun 2007
    Margaret River
    Not sure what the specs are but this what UG reads from PCM
    3.5K psi at idle
    21K psi at 2200 rpm flat road 100kph
    31kpsi is about 22k Kpa
    Aug 2017
    Rover
    Quote Originally Posted by Grappler View Post
    3.5K psi at idle
    Thanks very much for checking that Grappler. That’s about the same as I’m getting on UG too.
    Aug 2017
    Rover
    Thanks JC, I will try some CRD. Hopefully that will do the trick as it sounds like my psi/kpa is about right. ...assuming 34-3500psi (approx 24000kpa) would be within normal operating spec at idle?
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    Interesting that the 2 stroke mix comes into the equation again.
    I did it all the time with my D2 td5.
    It was originally considered not to add 2 stroke to the common rail engines and I'm very interested why the change of heart Justin.
    It did the td5 no harm over 100s of 1000s of kms.
    I would assume injector pressures in the td5 would be as high as the common rails?
    This was originally one the reasons not put any additives into your common rail diesel fuel.
    Any enlightenment would be much appreciated.
    Den
