Results 1 to 3 of 3
Thread: Air Suspension fault - C1A18-64
    Jan 2012
    Hi All,
    I had the fault C1A18-64 Pressure increases too rapid when filling reservoir - Algorithm based failure - Signal plausibility faill
    The orange triangle illuminates intermittently about 30 seconds after staring the car and resets after switching off and restarting. Has anyone seen this before and any suggestions what it may be?
    Geoff
    D4 TDV6 MY13 White - GONE
    NSW SW Slopes
    My assumption is that either the pressure sensor is faulty due to over-reading or the valve to the reservoir isn't opening properly.
    Jan 2012
    Hi all,
    well, i believe i have rectified my issue. I purchased a new Rear Valve Block RHV000055 from Ebay. Did the fitment this morning and touch wood, no fault codes or issues so far. I will be replacing the dessicant and O rings in the compressor tomorrow, as a maintenance item. The job was a little fiddly, however was done in an hour or so.
    I also purchased an O ring set for the Valve block, so will strip, clean and reassemble in the next few weeks as a spare.
    Geoff
