Thread: Prospeed roof rack - with a mesh floor?
    Nov 2017
    West of Perth
    As much as I like the look of the Prospeed roof rack, I'm not a fan of the solid floor.
    Has anyone put a mesh floor in, a la Tracklander/Jaram, or any of the generic fitting, gutter-mount jobs?
    Would it be possible to get something made up, or are the mounts too awkward?
    If at first you don't succeed, that's one data point. - xkcd
    2011 Discovery 4 SDV6 HSE
    Nov 2015
    Black Rock
    The ProSpeed floor is made up of (up to) 9 plastic panels which simply screw into place. They can be easily removed to fit accessories (like jerry can holders, spare wheel carriers etc.) or for lashing down awkward loads. It would be quite easy to manufacture a mesh floor and simply screw it into place onto the rack.
    The full floor acts like a tropical roof and I've noticed it keeps the car noticeably cooler when sitting in direct sunlight.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Oct 2014
    Adelaide
    If you want a mesh floor/platform Rhino make a perfectly good one
    Rob
    Rob
    MY15 TDV6. Compomotives with KO2's, Traxide 160-DBMS, Llams, OE bar, custom rear storage slide, Rhino roof storage system, LSM TPMS, ICOM 440N, rear ladder and GOE compressor guard
    May 2015
    Each of my plastic panels developed a noticeable curve/droop in less that a year even though my car is garaged most of the time. I guess this was due to the sun and heat but disappointing all the same.
    2014 D4 HSE, Traxide Dual Battery System, llams, Compomotive Rims, Prospeed Roof Rack, Rock Sliders and Compressor Guard.
    Nov 2017
    West of Perth
    Quote Originally Posted by Mog60 View Post
    I hadn't realised they are plastic until DieselLSE and you pointed it out. I don't have a garage or shade, so that's probably not a good idea for mine.
    I'm thinking mesh for easy tie down options.
    Ta for the advice.
