25th April 2006, 07:02 PM
25th April 2006, 07:43 PM
P.S. has standard fuel tank from manufacture
25th April 2006, 07:52 PM
Breather hose thingy on the tank is blocked?
Simon
25th April 2006, 09:28 PM
#4
ok now im going to sound like a tool .....ok so im a tool
where and which one what would i be looking for please
25th April 2006, 09:46 PM
#5
I think you've answered your own question Sith. I'm no expert here but it seems as tho' you've created some sort of vacuum, the pump by your description seems to be cavitating which will kill power...get out the air hose and blow the cap breather, and/or do the same to the inline fuel filters. Only going by experience, clogged fuel filters will kill your motor, as it starves for fuel, good luck and reply, interested to know what the prob is.....
GQ
25th April 2006, 09:55 PM
#6
Ok i will try the old process of elimination tomorrow .........
start with removing all lines and blowing them out
then try one of the old orange emergancy fuel caps ...as was suggested it may be that as they are designed to breath not lock as a vaccum
and change the filter element in the AC DELCO filter ....
will see how i go .....
once again thanx for the advise and relies :wink:
25th April 2006, 10:40 PM
#7
Just a quick one....
It's probably not the filter by virtue of the fact that when you take the cap off everything is OK.
My money is on the cap as IIRC they are supposed to breath.
Mark
26th April 2006, 03:24 AM
#8
Hi Sith,
I am with Simon on this - sounds to me like your fuel filler breather pipe is either kinked or blocked. I have heard elswhere of this happening with these exact same symptoms.
Should not be too hard to fix once you start fiddling with it.
Good luck.
Cameron
26th April 2006, 05:00 AM
#9
Originally posted by cameron
Hi Sith,
Good luck.
Cameron
Ahem... [cough] How do you explain it all working when you take the filler cap off then? If the problem was that far down the fuel system, it would still be there with or without the filler cap in place.
...but I am prepared to be proven wrong.
Mark
26th April 2006, 09:35 AM
#10
Sorry, wasn't clear enough, meant fuel tank breather.
Simon
