For the D4, I had an adapter for the bottle jack. Made by someone's son on this forum. I guess it might be best to do the same for the D5.
Ron
Hi All,
Absolute rookie question here. I want to carry a bottle jack and use when appropriate instead of the standard jack that comes with the d5. The bottle jack does not sit safely on the standard jack lugs and I am unsure where else to place it. See pics below. Can I use a bit of timber across the areas marked with the question mark and set the bottle jack against that?
Pic 1 one is behind the front wheel
Pic two is in front of the back wheel.
Ron
2016 D4 TDV6 Corris Grey
2018 D5 TD6 SE Silicon Silver - gone
2011 D4 TDV6 2.7 Indus Silver - gone
IIDTool BT
Thanks Ron.
It was a 3d printed one, the thread is here and has a drawing what it looked like on page 1. Needless to say the D4 adaptor isn't going to fit the D5, but the thread might give you an idea how it was done,
Ron
IIDTool BT
Thanks Ron. Appreciate you going back and finding the thread and looks like a good solution. I found this off the shelf adapter which solves the problem nicely.
6 Ton Pinch Weld Frame Pad – Safe Jack
I put mine under the axle, but that's on a Defender, of course, so different.
I've been wondering how I'm going to back up our new camper trailer if it ever gets a flat tyre. At this stage I can't see how any jack could work. My best guess is I'll use the stabiliser legs and the jockey wheel to try to get the flat tyre off the ground. No idea if that could work. Might need a trial run soon.
can anyone recommend a good bottle jack. I am hearing different things re different size etc.. Just wondering what works best.
I use the Bushranger Exhaust Jack.
It works anywhere, even under a LC200 with a camper on behind on the side of a mountain swinging from the winch of my D5.
Chris
