Thread: Recommendations please - L405 Roof rails & bars / racks
    Oct 2012
    I’m just about to take the plunge and buy a L405 & will need Roof rails and bars.
    Can anyone recommend a brand or place to obtain these at a “ reasonable” price. Thanks in advance.
    Apr 2010
    Gosford, NSW
    hi Orangepop,
    the original rails you get for $1800+ will include the replacement cover strips (finishers) with the slots/holes cut out to fit the brackets through. The cheaper copy ones ($400 - 500 ish) will not include those finishers, and you will need to cut your own holes in the existing finishers, some come with a template for the holes. Not a big deal if you want to keep them on all the time, but will look a bit odd if you remove the rails and the finishers with holes are left on show. (but you may be able to get replacement finishers a lot cheaper than the $ difference between the original and copy rails) With the rails you can fit cross bars at varying positions along the length of the rails. If you go just for the cross-bars without the rails you will be limited to just the positions of the holes in the roof, and you will still need to cut your own holes in the finishers.
    If you go with the rails, you should be able to get cross bars from Thule or similar to suit.
    Oct 2012
    Great info thanks Gregz, it’s a steep learning curve. Hoping to pick up the new girl this week
    Queensland
    Roof Racks - L320 RRS Expo Rack fitted to L405
    All
    Just on this topic, I posted on FFRR per below. I was interested in how LR fitted their old style OEM Expedition rack to the new L405.
    fullfatrr.com - View topic - Fitting RRSport L320 model Expedition Roof Rack
    Also, Front Runner do a rack for the L405
    Land Rover Range Rover (2013-Current) Slimline II Roof Rack Kit - by Front Runner
    L405, Vogue SE, 4.4SDV8, 8 speed, Rear e-diff
    Jan 2012
    Geelong Vic
    Re the LR expedition rack, LR state that max capacity of anything fitted to the roof rails is 100kg. Wonder why they carry those "empty" jerry cans ?
    2015.5 RR Vogue TDV6
    2016 XE Jag 20D Prestige
    2003 MB SL500
    Queensland
    Yes, quite (lol!!)! I recall seeing a photo of a D4 support car with the Silk Rd cars and it had 6 "empty" ones up there...!
    Dec 2009
    Ranelagh, Tasmania
    The load rating is more about the COG than the strength of the roof.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
