Results 1 to 2 of 2
Thread: resetting oil level indicator( Electronic)
    Jan 2010
    Lyndoch Brossa Valley
    Red face resetting oil level indicator( Electronic)
    Can someone assist with directions for resetting oil level indicator (Electronic) after oil change For 2014 Discovery 4 SDV6. I thought it was automatic but notice it is listed on Maintenance check sheet.
    Sep 2014
    Baldivis WA
    Not sure what you mean by "resetting"
    The gauge is effectively your dipstick. The level needs to read "ok" and the oil level indicated needs to be at the top. If too low add oil, if overfilled you need to suction out some oil until correct.
    I've never had to reset it.
