I bought an on car disc machine at auction some years ago. I used it on a few vehicles and on sold it. worked very well. Make sure your wheel bearings are to spec. Loose bearings give an untrue result. Main problem with them is that motor mechanics are not machinists and seem unwilling to take a decent depth of cut to get under the hardened skin that develops on cast iron from repeated heating and cooling. You need to be cutting in the soft metal under the hard layer or the insert might be skidding over the hardened skin. This also uses up the inserts early.
