Results 1 to 6 of 6
Thread: Replaced turbo hose
    Oct 2013
    Ballarat
    Replaced turbo hose
    I replaced the long turbo hose after finding a crack , change the oil , now no power and engine light is on .... Help
    What could be the problem any ideas please and I dont have a fault reader
    Sep 2014
    Baldivis WA
    Did you check that all the connections are tight? There's normally markings on the hoses that tell you where the clips do up.
    I assume the engine runs? So you're getting some air flow, but the enginr canr build up turbo boost cause it loses air pressure.
    Also check you've got no other leaks.
    Hope this helps
    Feb 2011
    Hobart, Tasmania, Australia
    What electrical connectors did you have to disconnect to do it?
    Oct 2013
    Ballarat
    hi all no electrical fittings checked all those , got it scanned dam EGR valves that are the problem funny how it worked before the new hose . Another job over Easter ..
    Mornington Peninsula, Victoria
    Quote Originally Posted by crawal View Post
    Definitely time for a re-map & delete .....
    Oct 2013
    Ballarat
    EGr's out what a pain oh to have long arms and taller ...Blanking plates ready I see why all the you tube show the drivers side
