Just a thought - have you checked/changed the plugs?
I'm looking at changing mine, but am a little daunted by how hard some are to get to - even my indie screwed up his nose when I mentioned it!!!
 06 Discovery 3 v6 petrol EGR problems
		Hey all,
I have a great Discovery 3 that has done 220k. However over the last 6 months I have had idling problems, stalling and not starting every time.
Originally I gave the throttle body a good clean, which helped the idling, car continued to stall and have rough starts, so cleaned the intake system through the throttle body, this has improved my problems significantly but still not perfect
One day I will have a diesel Land Rover!
Should I replace the EGR valve? is there such thing as a bypass for a petrol EGR valve?
Thank you
 Master
						Master
2012 L320 Range Rover Sport Fuji White
REMLR 012
No 5 Trailer ARN 177-295
2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
SOLD Engineers Trailer - no id
SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
SOLD 4MP COY Series 3 FFR 30-209
 Master
						Master
						Um, stupid question - do petrol engines have EGR valves??
REMLR 012
This one does. It doesn't get anywhere near as gunked up as the diesels, and the petrols dont produce the same amount of soot.
To the OP, as stated check the plugs and leads. If the car does lots of short trips it can foul the plugs as the car runs real rich when cold. And 220km and 10+ years is probably a good run for plugs
Stuffing around with the EGR would be my last check.
I have done plugs on a couple of other cars, but looking at the disco, the front 4 will be easy, getting the ones closest to fire wall don't look like fun. I'll give them a go soon and take some pics as I go.
I removed the EGR in about 30 minutes (quicker if i didn't drop the seal haha) cleaned it out and reinstalled next day, seems to be running well for now.
 Master
						Master
						Egr and MAP sensor are all in one, front of engine at throttle body. Easy to fit. They DO fail on the V6 4.0, usually with a MAP sensor fault. if The Barometer inside the ECU detects any more than a relatively small differential in readings to the MAF,it sets a DTC. 99.9% of the time it is the MAP sensor, which is part of the EGR valve.....
 Master
						Master
REMLR 012
