Results 1 to 10 of 22
Thread: New and old tyres on the same car
    Oct 2011
    Fremantle WA
    I recall a number of threads about not mixing tyres on the same "Axle", but what about between front and rear.
    Dilemma - On my just acquired D4, I have 1 brand new spare and 4 half worn 697s.
    I have access to a 6th rim and I'd like to get some use out of the newby, so was wondering if I buy another 697 (currently $485 on special for my size thank you very much) can I put the 2 newbies on the front and the partly worn ones on the rear (or vice versa), or will this cause angst for the centre diff?
    If I can, I'd keep the 2 newbies on until rotating the partly worn ones gives me an overall match.
    Thoughts from the wise?
    Mar 2016
    I’m running Maxis front and Cooper rear until the Cooper wear out and I get another pair of Maxis. It’s been fine.
    2007 Audi RS4 (B7)
    Sep 2014
    Baldivis WA
    To me, as long as they are the same size profile, you should not have any issues with mixing old and new tyres. Eg if one tyre is a 55 profile and the opposite side a 65 profile, the “smaller” tyre will spin marginally faster than the larger tyre at a given road speed. I’ve run old and new tyres before, but always the same size, and try to keep the ‘old’ set on the same axle
    DiscoMick Guest
    Should be okay I think, but think about grip for steering and strength for rear loads before deciding if to put them on the front or back.
    Oct 2011
    Fremantle WA
    Quote Originally Posted by DiscoMick View Post
    Yes, that was the secondary question. Given I plan to be towing over 3T, my thinking is to put the 2 newbies on the back with the higher air pressures.
    DiscoMick Guest
    Sounds like a good idea if towing a heavy load.
    Jan 2017
    Geraldton WA
    If you intend to use the D4 as a touring "tug" towing 3t behind it then personally I would bite the bullet and get 4x new tyres fitted to it
    It is never a Good idea to head off on a trip with half worn tyres and with winter coming up do you really want to trust the lives of your family and yourself to old worn tyres??
    4.6m Quintrex boat
    Oct 2013
    Old Toongabbie, Sydney NSW
    Quote Originally Posted by gavinwibrow View Post
    Be careful with a "brand new" spare. Is it actually recently purchased or just not used? Tyres degrade over time and whilst I would be happy for an old unused tyre as a spare to get me out of trouble, I would not put it into use full time to get some wear out of it. I just searched online for how long they should be ok and it ranged from 5 to 10 years if stored correctly. It was suggested that after 5 years they should be checked annually to be safe. It's to do with the tyre losing its suppleness and drying out basically.
    Martin
    DiscoMick Guest
    I agree with Trout that it would be better to buy four new tyres now, rather than be forced into it later. I once had two simultaneous flats on the rear of our D1 while towing because the tyres were half worn and couldn't cope with a corrugated road.
    And, as said above, if your unused spare is more than about five years old it may have dried out. It is possible to bath tyres in light oil to try to revive them, but the results are uncertain.
    Jan 2015
    Not to steer you away in any way from any of the good advice above, I have done exactly what you’ve described but without the towing. No issues whatsoever
    David
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
