if you have access, do it in place.
punch a hole in the old one and lever it out with a screwdriver or similar.
clean the bore of the hole with emery paper and apply a little "stag" jointing paste to the bore and the outer surface of the new welch plug and tap in using a socket that just fit into the inside of the welch plug and hammer in square.
no problemos.....
