Results 1 to 9 of 9
Thread: traction control light coming on - sharp corner while towing
    Apr 2016
    New South Wales
    I had this light flash on momentarily about three times on a weekend away recently, slow speed maybe up to 60km hr, sharp corner with a caravan in tow
    as far as I’m aware there was no sliding or wheel spin so I’m not sure why this would have triggered?
    Markus1 Guest
    I had this towing down in Tassie on a tight downhill switchback that I took a touch fast. There was no perceivable slide but as far as I was concerned it was just the system working as per normal. Potentially a rear wheel may have lifted a poofteenth but I really couldn't say. The brakes pulsated for a 1/2 second or so and then all was normal. The system is reasonably sensitive and presumably gets even more sensitised when in tow. This is good imo!! Keeping you safe.
    Nov 2014
    Nirvana near Albany W.A.
    as above .... normal , just the dsc doing its thing , the weight of trailer wanting to push the back of the car as you take a corner a bit quick
    Apr 2016
    New South Wales
    Good to know, thanks gents.
    Reassuring to know how sensitive the electronics can be
    Oct 2012
    Quote Originally Posted by Lukeis View Post
    But, if your car is not recognising the trailer is connected it will not compensate. Is the trailer light flashing when you indicate? A long subject well covered here if you plug LED trailer lights into the earlier models D3.
    Aug 2016
    There is a road out the back of Christmas Hills where I like to see if I can drive it at 100kph minimum. In my old car I would set the cruise control to 100kph and just add extra speed when I wanted and just back off on some of the sharper corners without braking. In the D4 the TC takes over and disenguages the cruise control as well as the light flashing. Not using the cruise control even with the foot on the pedal the TC takes over and takes off the power. Bit annoying as an ex rally driver I like to have a bit of fun! Not sure which button would stop that happening. DSC?
    2016.5 TDV6 Graphite D4,Corris Grey,APT sliders,Goe air comp plate,UHF & HF radio,Airflow snorkel,Discrete Winch,Compo rims with 265/65/18 Wildpeak AT3W, LLAMs,Traxide dual battery,EAS emergency kit,Mitch Hitch EGR blank & delete,ECU remap
    Sep 2012
    Adelaide Hills
    Quote Originally Posted by dirvine View Post
    press and hold.
    cant turn it off completely but will make it less sensitive.
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Dec 2009
    Ranelagh, Tasmania
    I used to turn off DSC when towing with my D3 as it was very intrusive. the D4 was much improved but on especially windy roads I would sometimes turn it off. Check your tyre pressures as well as discrepancies across axles won't help.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Apr 2016
    New South Wales
    Quote Originally Posted by PerthDisco View Post
    Yep thanks, sorted that debarcle out already!
