Results 1 to 10 of 24
Thread: Gunna need a bigger bonnet
    Jul 2013
    sydney
    Hi all
    Any suggestions for modding a perentie 6x6 bonnet. My thoughts so far are:
    1. Try an fit a falcon BA power bulge ( would also replace the thermostat housing cover)
    2. WRX style scoop (issues with hp air entering engine bay reducing flow through radiator, fugly )
    3. Make a one off mould of existing bonnet using plaster of paris and after removing bonnet, fill and shape in power bulge and lay up new fibreglass bonnet (most work but could be best looking solution)
    Bob
    Bob
    Perentie 6x6 Motorhome (Truck, cargo, light, winch, MC2)
    '96 Discovery 1 300TDI Manual
    Discovery 4 TDV6 - Gone
    Discovery 3 HSE - Burnt....
    May 2003
    On The Road
    does it need airflow? and would the difference be noticable if it got it?
    holes in bonnets are always a tossup..
    just fyi,, the D2 bonnet has a huge no-pressure area that close to the windshield..
    go for a drive in the rain and check before cutting anything
    I do like the idea of a power bulge
    NSW far north coast
    It's a water/air IC Pedro so doesn't need air.
    Maybe a Tdci bonnet?
    Jan 2017
    Geraldton WA
    Maybe you could fit a Navara scoop, They are a fairly big unit and would be an easy fit as well
    4.6m Quintrex boat
    Jun 2016
    United States
    Forgive my naivete......what is this and why was it necessary? I presume something having to do with air and the turbo.....and if beneficial, would I want one?
    Scratching my teenage itch now that I'm in my midlife crisis...
    '87 110 County 4BD1+T+LP (Godzilla)
    '88 110 Perentie Cargo 4BD1+T+LP (Thing1)
    '91 110 Perentie Cargo 4BD1+T+LP (Thing2)
    May 2006
    Woolgoolga
    Quote Originally Posted by tc_s1 View Post
    It's a water to air intercooler. Everyone needs oneGunna need a bigger bonnet.
    Although I just sold mine Gunna need a bigger bonnet
    May 2006
    Woolgoolga
    How much does it miss by? May be you could change the rocker cover to the flat one, that should give you another 15-20mm, that's what I did with the same cooler in my rangie.
    Jun 2016
    United States
    Quote Originally Posted by Vern View Post
    Aha, got it now. Gunna need a bigger bonnet
    mount it to the passangers side..
    have you seen the canyon that exists between the inner wheel guard and the engine?
    I routinely sit on the passangers side wing with my feet on the rail and starter when I'm doing valves on the 6x6,,, (its easier than leaning over)
    acres of room..
    I'll just leave this here....
    Insert the.....
    Part shamless plug, part fun part youve got to be kidding...
    enjoy...
