Results 1 to 6 of 6
Thread: Shutter sticks
    Kilmore, VIC
    106.38 MB
    Shutter sticks
    My left hand HID sometimes (often) sticks in the high beam position. Hit a bump or get out and give the headlight a thump and it drops back to low beam. Cycling it a few times usually drops it, but not great for oncoming traffic... Car spent the first decade of its life in the big city so I suspect the High beams weren't used much or at all.
    Does anyone know if there's a quick/easy/ cheap fix? Can they be lubed or freed up? Mine are the non adaptive(cornering) if that makes a difference. I suspect the basic gubbins are the same as D3/4.
    DiscoClax
    '94 D1 3dr Aegean Blue - 300ci stroker RV8, 4HP24 & Compushift, usual bar-work, various APT gear, 235/85 M/Ts, 3deg arms, Detroit lockers, $$$$, etc.
    '08 RRS TDV8 Rimini Red - 285/60R18 Falken AT3Ws, Rock slider-steps, APT full under-protection, Mitch Hitch, Tradesman rack, Traxide DBS, Gap IID
    Kilmore, VIC
    106.38 MB
    * bump *
    DiscoClax
    Mar 2016
    I’ve never heard of the issue and that might be the same for most which might explain why no one is chiming in?
    2007 Audi RS4 (B7)
    LRD414's Avatar
    Oct 2014
    It's a known issue. I can't find the AULRO thread but this Disco3 thread should help.
    It's a fiddly fix that requires access inside the light housing.
    DISCO3.CO.UK - View topic - sticky headlight probably solved
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Mar 2016
    Well there you go Shutter sticks
    2007 Audi RS4 (B7)
    Kilmore, VIC
    106.38 MB
    Thanks Scott. Great find. I didn't think of checking out the UK forums, but somehow knew someone on here would be able to help I'll fire up the laptop a bit later and see if the pictures are visible (they are not on my phone). Even if not the description should be enough to follow. Looks (sounds) like a much better option than replacing the lamp unit...
    DiscoClax
