Results 1 to 10 of 16
Thread: Buying 2014 (or there abouts) D4.
    Jul 2012
    Perth- South of the River
    Hi All,
    As per previous a thread about a specific D4, I'm looking to buy a later model D4.
    I've driven a couple today and I would like peoples thoughts on a couple of things. Both are 2014. HSE with the same options.
    63k car at $64k and is set up with triple batteries by Autospark in Ozzy Park, a snorkel and brake controller.
    131k km at $50k is from Karratha (Wickham precisely) and has a rack.
    Questions:
    1. The 131k car, during the test drive had significantly better performance. It was significantly harder accelerating than my D3 and really pushed me back in the seat. However, the 63k car felt only marginally better than my 3 and nowhere near the other 4. NB: Definitely both SDV6 (on the badge and on Topix). What are peoples thoughts?
    2. This is the second time I have driven the 131k car. The first time last week it had the low battery warning and when started it really struggled to turn it over, but did start it. On driving it today, the guy said that they'd replaced the battery (I confirmed visually) however, near the end of the test drive, a fault came up and HDC, Emergancy Brake Assist (or whatever it is) and something else realated were disabled and car lowered for safety. On returning the guy said, no worries we thought this was the battery, but don't worry it's just be some power draw and the car is turning off these systems to conserve power (this sounds reasonable and plausible). What are peoples thoughts?
    Also, if anyone knows the Wickham car that would be good.
    Thanks in advance.
    Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
    Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
    LRD414's Avatar
    Oct 2014
    Quote Originally Posted by Dagilmo View Post
    Could have been re-mapped. The 2014 models require the ECU out to be remapped but I don;t think there's any physical way to tell. Also could have one of those throttle controllers.
    That is bollocks. There is a problem/fault with the vehicle.
    Regards,
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    DiscoMick Guest
    Personally, I'd go for the lowest possible kilometres I could afford.
    Jul 2012
    Hi Scott,
    I did think remap. It really goes like a scolded cat. I probably need to drive a couple more to compare. The sales guy talked the difference down saying that adaptations would make a difference and the other car would perform better with some spirited driving....Interesting since he's not wanting me to buy the other car...
    Update on faults: The dealer just called and said all fixed now. Was the wheel alignment (now I'm saying that's correct, however it did need an alignment, has had lower control arms replaced just now and whilst it wasn't 'pulling' the steering wheel was on the p#ss a significant amount when driving straight) apparently.... "when you turned the wheel too far it caused it to fault" "Wheel alignment done and all fixed..." I'm calling BS on this one. When it faulted I was on a straight bit of road and just turning slightly into the right turning lane.
    Jul 2012
    Quote Originally Posted by DiscoMick View Post
    That's been my thoughts also, as this car will be a long term thing for me.......but the difference in driving performance has me thinking
    Jan 2018
    Lilydale, Victoria
    I agree with a number of the above comments about buying the lowest kilometres you can afford. The one from the Pilbara May go hard but I would check very thoroughly underneath it as there a lot of gravel roads up there and if it had been remapped could possibly have been driven hard. If you can drive a couple of others for comparison that would be very useful.
    Whichever one you choose I would be looking for copies of all service invoices and get a thorough check from a good Indy, before you hand over any money.
    I bought my 2016 SD6 HSE with 65000km on it and had a full RACQ check and a lengthy conversation with the testing agent. I had him so worried that he even sent me photos of the very minor scratches in the bottom of the cup holders.
    Needless to say, I’m very happy with it.
    David
    LRD414's Avatar
    Oct 2014
    It’s hard to know unless you drive them yourself but gearbox adaptations do make a difference. Whether enough to match your experience I don’t know.
    D3 2005 V8 Petrol
    DiscoMick Guest
    Hi Scott,
    I'm not an expert on these cars so I could be wrong, but is it right that the software does adapt to the driving style, so a car which has been flogged might have developed a different profile to one which has been pottered about. Or is that wrong?
    Oct 2013
    Old Toongabbie, Sydney NSW
    Previous posts on this forum would support that. It will change depending on your driving style. Can't remember how long it takes to do so though.
    Martin
    Mar 2016
    It’s been reported on here before that when the wheel alignment is too far out it causes various failures messages etc so I would be inclined to believe what they say in that regard.
    2007 Audi RS4 (B7)
