Results 1 to 10 of 18
Thread: Buying 05/06 Defender
    floyd Guest
    Hello Landrover Heaven
    Hi I am new to this forum. Started my 4WD life with a S3 lwb LR, but changed to the dark side and have been driving for the last 6 years a GQ patrol. It has been a good rig but something has been missing- Passion.
    Need a landrover again.
    I know the TD5 Defender is pretty reliable these days and build quality has improved. Great tourers etc
    As daily drive what is it really like? I have to drive 60 - 90km a day through 90+ sets of traffic lights accross Sydney . What is it like in town with the stop start traffic jams etc. A Mate has a TD5 disco and drives less km's and has to have 4 disc rotor replaced after approx 40,000km cost $2000.
    6 years of driving the GQ accross town and I have had 2 sets of front brake pads and 1 rear never any disc rotors changed. Is more costly to maintain a defender than a patrol? No salsbury rear diff now is this a problem?
    Thank you
    Re: Buying 05/06 Defender
    6 years of driving the GQ across town and I have had 2 sets of front brake pads and 1 rear never any disc rotors changed. Is more costly to maintain a defender than a patrol? No Salisbury rear diff now is this a problem?
    Thank you
    He was probably ripped off.
    I recently replaced the rears on my P38A (1995 RR). I did the work myself because it is easy enough (even easier on Defenders and earlier RRs and Discos which don't have sliding callipers). The rear discs were about $100 each plus a set of pads for under $100. My Rangie has 200,000km on it and I've had it for 85,000 km. This the first rotor change I've done. My previous RR I had for well over 100,000km and I never changed the rotors. That Rangie was used for 5 years to take me to/from Emu Plains to Paddington, i.e., across Sydney, 5 days a week for work
    Ron
    May 2003
    On The Road
    have to change you tag to GUNGADIN if you do it--- I wouldnt do 90 lights in a year
    but-- there are a lot of passionate Defender drivers in Sid in e, who probably do that and not blink.
    you could search the TECH forum for brake problems in defenders, but off hand I dont think its a huge problem,, mastercylinders now THERES a problem,,
    join in any time Zook
    as for D2 rotors,, yea, about 80K is average, Rons pricing is good but people are now using aftermarket discs and pads.
    From reading here, build quality changes from car to car, one mans leak is anothers downpour.
    Passion?
    is the defenders middle name.
    Yass NSW
    I drive 150 km a day for work in my Defender but most of it is highway. Only 6 sets of lights and 3 roundabouts each way. I love it and find its more fun than a sedan. Cost is about the same as a normal car (At least for me).
    Padstow NSW
    hi and welcome!
    brake pads and rotors will be an issue, they seem to be really soft.
    but as others have stated you shouldnt pay over $90 each for rotors
    unless you put ADB ones on. the pads are more expensive than the rotors 8O . oh and to change pads it takes a pry bar, and a set of pliers. and i spose the wheel has to come off
    i cant say much for the 110 in traffic, but my 90 is great. i had a training
    corse at hornsby on thursday(from revesby via No.6 and pennant hills rd)
    and its as zippy as any other in traffic, and i drive like shooie :wink:
    ive had my 04 90 for 3months now and i would buy another in a flash
    if i could.
    cheers phil.
    Garfield, Victoria
    I've had my Defender for nearly 2 years now and have had only minor warranty work (chipping of top edges of front windows), and no drivetrain problems.
    The main problem with the Defender is rear visibility which is a little worse than the Disco's, Rangies or the Jap brigade, and the turning circle, which I find a real pain in comfined situations. It is not a great town car largely because of this problem, but one learns to adjust to it. Visibilty forwards is excellent - a LOT better than the Japanese vehicles
    Performance is not a problem, and you will not hold up traffic.
    But, for heaven's sake don't buy a Defender if you are not intending to take it into the bush. It is there that it comes into its own - leaving most of the rest floundering.
    Lionel
    Eidsvold QLD
    Yeh, the turning circle is a PITA round town, and I also find the low first gear a bit of a bugger off the lights, quick up changes become natural though.I know when I bought mine I was driving it home from the city and I thought "christ, ive just spent $50k on this!!" (love it now tho)But i had never driven one before, best piece of advice is take one for a run round the suburbs.
    South Yundreup,WA.
    I have had no probs with my rotors (115,000kms). If I did need to replace them it would be with DBA Gold slotted and cross drilled items and Bendix 4x4 pads. I replace my 84 Rangie with these items, did all wheel bearings seals oils etc at the same time plus got a spare set of brake pads for about $700 delivered to my door from Sydney. Cheapest in Kalgoorlie for same items was around $1100. For someone else to do it $2000-$2500. Not a hard job at all, just allow a full day. Much better braking. Will more than likely upgrade the fender the same way when these ones are stuffed.
    Craig
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Yass NSW
    Have agree about the rear visability and turning circle. You get used to it though. Handling and stopping is quite good, especially when you look at the size and weight. My monster is fast if you drive it hard but uses the fuel then as well.
    Panania
    I love my defender around town... sure rear visibility and turning circle is a bit of a hassle + also parking in some under cover garages, especially if you have racks... but I friggin love it. My landy has been off the road since thurs night (fuel pump problems... another story), and after hooning around in my auto 03 commodore wagon all weekend I can't wait to hop back up into the drivers seat - hand-brake hard against my left leg and window hard against my right elbow.... don't ask me what it is, but I can't live without it!! It's raw, it leaks, it's my landy!!!
    I drive 30-40 minutes each day in peak-hour traffic... usually no worries. One thing I have noticed is that my general "pace" has slowed down a fair bit... not that I have any problems keeping up or accelerating from the lights, but if someone needs to get ahead of me then so what... I just let them go.
