Results 1 to 10 of 16
Thread: Aerpro FP8409K Install kit to suit Landrover discovery 4 - allows aftermarket double
    Feb 2011
    Hobart, Tasmania, Australia
    Question Aerpro FP8409K Install kit to suit Landrover discovery 4 - allows aftermarket double
    Anyone used the Aerpro FP8409K Install kit to suit Landrover discovery 4 < Aerpro | First Choice >? Particularly interested for those with the base model TDV6 with the factory LowLine audio system (that has the smaller factory LCD screen and no factory reverse camera or apparently any reverse camera compatibility).
    Looks like the kit would allow the installation of an aftermarket double DIN headunit which means even Apple CarPlay or Android Auto can be added (I'm liking the Alpine iLX-702D < iLX-702D Alpine Electronics of Australia > for this with Apple CarPlay Wireless, built-in or external bluetooth microphone, reverse camera and SWC compatibility it ticks our requirement boxes - as a bonus even has DAB with the add on antenna) while retaining the factory steering wheel controls using the included Steering Wheel Control Interface and Universal SWC Patch Lead.
    My main concerns are:
    1. It has the clock relocation panel but our D4 (MY12 TDV6) doesn't have a round factory clock on the dash.
    [img]148452d1550191762-d4-does-colour-colour-dash-screen-mean-reverse-camera-fitted-screen-shot-2019-02-15-11.46.40-am.jpg[/img]
    I wonder if it's possible to fit one from a later model - it is just a power feed line that's needed for it? I assume it's more complicated than that though as it looks like it might have six pins on the connector and doesn't have adjustment buttons on the clock face itself. I guess one option is to source and fit a second hand clock even if it doesn't end up telling the actual time it would still fill the hole...
    [img]Radio-Entertainment-Information-Control-Switch-Clock-Oem-Land-Rover-LR4-10-11-272486864510-3.jpg[/img]
    [img]Radio-Entertainment-Information-Control-Switch-Clock-Oem-Land-Rover-LR4-10-11-272486864510.jpg[/img]
    2. The handsfree mobile phone bluetooth in the D4 is amazing - best I've ever had/used/experienced for clarity for both ends of the call - wonder if that would be lost with an aftermarket headunit?
    Feb 2011
    Also just found https://www.naviplus.com.au/single-p...screen-upgrade which looks worth a read into.
    josh.huber Guest
    I reckon you would defiantly loose quality if you went aftermarket head unit, but you may be able to retain the Land rover blue tooth some how. If your driving through Sydney get in contact with Cameron at Old jaguar, he's a gun with stereo upgrades
    Oct 2011
    Fremantle WA
    Quote Originally Posted by twr7cx View Post
    Good research. I too don't have a clock (the time is displayed in the non touch screen), but the manual at the top of page 5 at item 14 says:
    Note: if retaining the original clock, reconnect it now and install it into the new fascia panel during Step 5. If not, the included blanking panel can be inserted into the fascia panel.
    I assume it retains AM/FM in addition to DAB? I didn't notice any reference in my quick look.
    Your second find is no good to me - only for 2012 MY onwards.
    Keep up the good work!!
    Jul 2015
    Sydney, Australia
    I looked at these when they first came out, the wiring interface in the kit is only suitable for the high-spec system, with factory touchscreen, and MOST fibre optics, not the low spec system.
    It's a useless product.
    2009 Range Rover Sport 3.6L TDV8
    2017 Jaguar XE R-Sport
    Supercharged
    Jags XKR & XJR 4.2L S/C
    Old Jaguar Australia - www.facebook.com/oldjaguarau
    Upgrades and retrofits for late model Land Rover and Jaguar vehicles. www.oldjaguar.com
    Oct 2011
    Fremantle WA
    Quote Originally Posted by Cambo@oldjaguar View Post
    Don't know if it is a recent initiative, but is it possible they have rectified this with the following excerpt from their site? I'm also particularly interested cos I have a My 10 non touch screen poverty pack.
    Note: A Secondary Harness and Patch Lead (unless a universal Patch lead is supplied) is still required, these are specific to the aftermarket headunit being installed, we suggest using the appropriate APP9 kit or APP8 if a universal patch lead is supplied in the kit.
    The links take you to specific headunit manufacturer patch leads.
    Cheers and thanks for taking the time to comment.
    Jul 2015
    Sydney, Australia
    Secondary harness is what plugs into your new head unit, gives you ISO plugs to connect to the Aerpro harness.
    Patch lead goes from the new head unit to the steering wheel controls interface.
    Problem is the Aerpro harness has the connectors for the high-spec system, and a MOST fibre optic interface. The low-spec system is totally different.
    Supercharged
    St Helena,Melbourne
    4.28 MB
    Different car but the aerpro harness I used had iso plugs so will fit anything that has iso sockets built in , patch lead required for brand specific models.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Feb 2011
    If it only works with high spec vehicles then it likely is very useless as they'd be very little benefit/incentive to upgrade!
    Feb 2011
    Quote Originally Posted by gavinwibrow View Post
    the manual
    The manual indicates that the actual manufacturer of the product is Connect2 < Connects2 Ltd > and they supply just the mounting hardware. Aerpro are adding in those particular adapters and cabling so wonder if they can supply or get adapters to suit the LowLine models instead.
