Thread: 3.9 idler pulley
    3.9 idler pulley
    8) does anyone out there know the part no. for the idler pulley bearing .
    the engine is a 3.9 in a disco, with serpentine belt 1995.
    mine made some noise then threw the belt, luckily i was only puttering in the shopping centre car park near home.
    i have got the bearing out but it has no numbers on it.
    Safe Travels
    harry
    S.W. Sydney
    Dont know the part No but BMI in Windsor were selling the bearing without haveing to buy the whole thing (if I'm thinking about the right bit)
    Tony
    8) thanks tony, i might try them tomorrow as we have a public hol here tomorrow, so the locals will be closed.
    Safe Travels
    harry
    St Helena,Melbourne
    4.28 MB
    Take the bearing to a bearing place, they will measure and supply a replacement.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    8) and the part no. is '6203.2RSR'
    Safe Travels
    harry
    Somewhere else, QLD
    Idler puley
    If you haven't already sussed it out, the idler pulley is a standard thing that can be found on LR, Ford and GMH vehicles. If the bearing on your failed one has removeable clips, they you can buy a 6203 bearing from CBC ( or any bearing shop) for $8, remove the clips, hammer the old one out, and using two big washers and a nut and bolt, press it in . ( I have previously recommended using the old bearing to drift-read hit with hammer- in, but using the washers keeps the side seals intact, so the bearing lasts longer). if you can't find a replacement complete pulley at LR - try GMH ( VR C'Dore and similar Falcon)
    Langy
    8) thanks langy, she's fixed mate.
    trouble here was that qld had a public holiday on monday so i was trying to source from other areas and couldn't identify the bearing to phone order it.
    alls fixed now.
    Safe Travels
    harry
