Results 1 to 10 of 17
Thread: Air Flow - calculation challenge.
    Apr 2019
    I’m struggling to work out the air flow out of a pressure vessel.
    90m3 vessel @ 120kpa
    4” outlet, fully opened
    How do I work out the rate of air flow out of the vessel (to atmosphere) in either m3/min or CFM.
    Kallangur, Brisbane
    Good luck. We only deal with leaks here, the oily type.
    + 2016 D4 TDV6
    May 2012
    Wannanup WA
    4.70 MB
    Quote Originally Posted by W&KO View Post
    Good luck with that!
    Gas Discharge Rate Atmosphere From a Pressure Vessel | Engineers Edge | www.engineersedge.com
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    I don't think you can.
    Quite a few years ago an engineer where I was working tried to measure the open flow rate of steam on I think an 8" line.
    he fired up the boilers and got full head of steam and then opened a v/v with a flow meter some 12" or so in front of the open v/v.
    all that happened was that within minutes all the boilers ......and there were a number of them....were at full burn , the stacks were belching black , the Weir pumps were working like jumping jacks , huge amount of vapour going into the sky and we nearly all fell around laughing.
    btw , this was Australia's largest cotton textile plant, so there was serious boiler power.
    Absolute or gauge?
    Apr 2019
    Absolute or gauge?
    Er more info
    Compressor is turned off
    De-pressurizing
    Need to know max air flow leaving vessel.
    May 2012
    Wannanup WA
    4.70 MB
    Er more info
    De-pressurizing
    Err, I am inclined to think that I can probably fart more than what you are asking. 120 Kpa is 17.4 psi. Through the size outlet you are quoting the pressure will equalise within a few seconds, that is if you can fully open the orifice instantly.
    If you neglect viscosity, Bernoulli's equation (just Navier-Stokes without frictional or stress terms) will get you into the ballpark:
    Pg+12ρgv2g=PaPg+12ρgvg2=Pa
    fluid dynamics - Calculate flow rate of air through a pressurized hole - Physics Stack Exchange
    Apr 2019
    Quote Originally Posted by Old Farang View Post
    Keep in mind it’s a 90m3 vessel, 40 foot long by 3.2 meters round. It probably takes 10min to de-pressurize. For the first few minutes the airflow comes out at a rate of knots and I need to clean the air. The current systems are undersized, while limiting how much we open the valve this increases de-pressurize time.
    Kinda hoped there would be a simple calculation.
    May 2012
    Wannanup WA
    4.70 MB
    Cannot be a simple calculation as the pressure is continually falling.
    What is "3.2 metres round"? Is it circumference, diameter or what? You also need to use the same units to even calculate the volume of air in it.
    Apr 2019
    Yep, just need the max. Air flow at the start, understand it’s constantly dropping as it does get to zero.
    Sorry 3.2m diameter x 12m long, only gave the above measure to give an understanding of size as it doesn’t equalize instantly. I believe you only need
    capacity (volume) 90m3 and
    pressure 120kpa
