                                                20th May 2019, 10:34 AM
			7/10 FL2 TD4 turbos past 100k fail
					Hi all,
 Just wanted to see what peoples views are on what the local Land Rover service centre said about the FL2's turbos.
 I purchased an 09 TD4 FL2 at 130k km's and noticed boost blow off and the power loss at 1800rpm, so took it back under warranty and Land Rover said "7/10 of the turbos on the FL2's that have done over 100k km's fail and need overhauling". As it turned out the turbo on mine needed an overhaul.
 I did a fair bit of research before purchasing and never noticed the turbos coming up as a common issue.
 Anyone experience the same?
