My Fronius non-hybrid inverter has a data management option whereby a user-supplied relay with 12V coil and 240V contacts is switched on and off according to the amount of surplus power being exported. I generally set the limits to switch on just below the maximum allowed export of 5kW and off at 1kW as the HWS element is 3.6kW but mid-winter I set the limits to switch on when 4kW export and off when nil export. A lower rated element (eg 2400W) would allow the HWS to switch on more often but I always have the option to switch on the original HWS timer set to off-peak times (overnight here).
My electrician installed the relay in parallel with the HWS timer (which had been set to off-peak but now almost always OFF) and I supplied the 12V supply for the relay coil.
Because my PV system including the inverter is distant to the house, I provided a master/slave wifi system that is switched by the inverter's 12V o/p which in turn switches the relay coil at the house. If the PV system was on the house where the HWS timer is located then its a simple 12V connection from the inverter to the relay.
