Results 1 to 10 of 14
Thread: Suspension
    Mornington Peninsula Vic
    Suspension
    G'day All,
    I know that suspension keeps raising it's head, but would like to ask our illustrious members their thoughts and opinions on the subject;
    03>TD5 Defenders - Who has had aftermarket suspension fitted and what type of shock/spring combination are they running;
    Those who have fitted aftermarket, did this involve a raise and to what point in mm were they raised.
    Has this had an effect on their drive line, ie vibration or excessive wear and tear.
    Those who are still running standard LR suspension, how do you find this.
    and what sort of issue have you had if any.
    Lastly what sort of KM have you had out them.
    Your thought and opinions would be very much appreciated. I am sure I would not be the only one out their asking this.
    regards
    Jake
    Gilderoy, Victoria
    Can we please put this topic and associated threads in the common threads area? 8O
    I'm sooooooo bored.
    No offence Jake.
    Mick
    1999 Land Rover 110 Defender TD5 Cab Chassis
    1985 Land Rover 110 County 4.6 EFI V8
    1993 Track Trailer camper
    South Sydney
    Jake
    Everything is a compromise when it comes to suspension. Need to understand what you are going to use your defender for.
    What is wrong with the standard config?
    Is it for predominately touring?
    What weights do you intend carrying? What accessories do you have fitted to the Defender? (ie, bullbar, winch etc)
    'Kimba' is currently set up for touring. Because of the weight we lifted the front by about 35mm which has now settled back to standard with bar and winch and 50,000kms.
    Rear is standard springs but fiited polyairs for the additional weight.
    Replaced all shocks with Bilsteins. This was an ideal setup for touring, but if playing every weekend you would probably want softer springs and a greater lift, longer shocks, etc etc etc.
    ____________________________
    Noddy
    - 'Kimba' ('02 Defender Xtreme 110)
    - 'Ari' (1994 Peugeot 205GTi Classic)
    "...we are all just earrings to the left of our parents, and they are all just haircuts to the left of theirs..."
    Eidsvold QLD
    Re: Suspension
    Originally posted by jake
    G'day All,
    regards
    Jake
    I'm with Jake, this question gets raised and half covered, why dont those with suspension mods all explain their set up in detail and the whys and why nots and then get INC to stick it somewhere, (you know what I mean INC.)
    Gold Coast, Qld
    Re: Suspension
    Originally posted by crump+--><div class='quotetop'>QUOTE(crump)</div><div class='quotemain'><!--QuoteBegin-jake
    G'day All,
    regards
    Jake
    I'm with Jake, this question gets raised and half covered, why dont those with suspension mods all explain their set up in detail and the whys and why nots and then get INC to stick it somewhere, (you know what I mean INC.)[/b][/quote]
    Yep I agree, I am also trying to sort out my D2 suspension but it is a mine field of variying opinions. A detailed suspension section would be awsome.
    My 2c, Mick
    '99 Manual TD5 D2.......heap of money spent on it and it has ended
    Wheelers Hill, Melbourne
    I might as well chuck in my pennyworth.
    The only reason you would need to raise the vehicle is if you want/need larger tyres because you need the extra ground clearance and it follows- body clearance so they dont rub. End of story.
    You would only want larger tyres if you get "hung up" when you 4wd. end of that story.
    The way the tracks near Melb are heading my next vehicle will be a Unimog, I get hung up on 35" tyres, its a joke.
    So it all depends on what you want to do, you can get plenty of tread variations in standard 235 or 16" configeration. Just raising the body will not give you any better off road ability, rather make the tip over angle worse.
    For what its worth I got an ARB/Old Man Emu after market kit fitted they were 705mm front and 750mm rear, which is a small lift, they settled 10 mm after 500klm.
    One shocker **** itself after (quite) a few circuits of the Landrover 4wd test track at the Wandin Vic 4wd show and was replaced at a half price to me as goodwill. The suspension has settled on one side too much now after 10,000 klms- 65% of which is hard 4wding as I get around in a company car usually.
    Then again I have 200l of petrol and an 80Litre LPGas tank plus my 105 kg all on the driver side so I guess something has to give 8O
    8O
    Piggabeen (Tweed Heads)
    suspension
    Jake
    Subsribe to a Land Rover magazine and read and keep reading. Drive as many different set ups as you can if you are in a club, talk to as many people as you can then make your own mind up. You might get it wrong the first time but thats life. The ultimate suspension set up is a compromise that you will be happy with. If it helps it took me 3 sets of springs to get it right (for comp work lots of atriculation but it had to be driven to and from).
    Good luck
    Regards Justin
    99.87 MB
    8O
    Keep in mind that this is from a Victorian context, a region that seems to have a significant number of deeply rutted tracks. It most definately does not apply to NSW terrain. I've watched a number of 4WD's that have taken that approach to suspension setup, and have not been able to do some tracks (eg the bottom end of slippery Roc Rd) purely because they've just sat on their belly and lacked the ramp over angle. Lift beyond that required to fit tyres will increase offroading performance.
    Slunnie
    SYDNEY -in the shire.....
    Re: Suspension
    regards
    Jake
    <span style="color:blue">im still running the original shocks and springs......
    the front has sagged a bit after almost 85,000kms.....but still going ok....
    it does get used and abused when off road....and still gets me through in standard trim.....</span>
    tombraider Guest
    Re: Suspension
    Your not trying hard enough then
    Mike
    4" lifted Defender Tombraider
    Castor Corrected front arms
    Re-aligned rear arms
    LTR shocks
    Custom springs
