Results 1 to 6 of 6
Thread: Bluetooth Driving light relay.
    Dec 2011
    Adelaide
    142.79 MB
    I'm planning to have a little play fitting a bluetooth relay for my 2 LED driving lights.
    This is what I've ordered: E2A9 DC 12V 4CH Channel RF Wireless Remote Control Relay Switch 2 Transceiver 692463098450 | eBay
    and it looks like this.
    I trying to figure out the wiring!
    There is a single (+) and (-) input at the bottom of the picture, but there are seemingly 3 outputs marked A,B and C.
    Anyone have any ideas on what wire might go where????
    2012 L320 Range Rover Sport Fuji White
    REMLR 012
    No 5 Trailer ARN 177-295
    2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
    SOLD Engineers Trailer - no id
    SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
    SOLD 4MP COY Series 3 FFR 30-209
    Kallangur, Brisbane
    The + & - need 12V. This would be to power the device.
    I would guess that the 4 channels of A-B-C would be made up of a common, a normally open contact & a normally closed contact. You should have some documentation showing which is which otherwise you can test with a multi meter to figure which is which. I would use this device to drive an automotive type relay which in turn will power the spots. (Just my opinion)
    What are you going to use the other 3 channels for?
    + 2016 D4 TDV6
    Dec 2011
    Adelaide
    142.79 MB
    I haven't received the unit yet, so with luck there will be some details.
    The additional 3 channels are for "future modifications and ideas"!
    REMLR 012
    Aug 2010
    Sunbury, VIC
    You’ll need to check with a meter, but my guess is between a and b is normally open and between b and c is normally closed. So, if you just want to tun on something when the relay is active use the normally open contacts.
    Jul 2014
    west of Transylvania
    Aug 2010
    Sunbury, VIC
    Cool, confirms what I said. 👍
