Results 1 to 10 of 14
Thread: discovery issues
    Discolns Guest
    discovery issues
    Hi all,
    I have a few issues with my disco 3 2007, firstly the Electronic hand Brake, it being making a shocking sound and from what I read so far, it needs to be looked at by a landrover mech, but two have told me without looking that it will be a replacement $2000. Has any member had just a clean and service done and it corrected the problem?
    issue two: tail gate door opener failed so stupid me order a overseas import and to cut a long story short had to solder the wire and guess what the fault has returned, do I go to car electrician and get the job done right or buy a new one again ( been told it is linked to your car vin number, I don't see how)
    lee
    discovery 3 2007 SE
    discovery 2 2001 HSE LOVE YOU BABE
    discovery 1 1997 manual - SE
    St Helena,Melbourne
    1.13 MB
    If you search for Bodsy's brake bible on the disco3 UK forum there is a detailed post on how to service the EPB, tailgate issue can only be the actuator or the button so replace either or both should do the trick.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    The park brake problem is a common fault. It is making a noise because the mechanism which pulls the brakes on is travelling too far. If you continue using your hand brake it will eventually jam. The drum shoes themselves may just need adjusting at this stage.
    Search for Bodsy's Brake Bible. You will find instructions to adjust your parking brake drum shoes. You may need to recalibrate the 'Longitudinal travel' as well but you would need access to a GAP tool or similar.
    Basically, mechanics replace the units because it easier to do that than fiddly about with them but they can usually be returned to proper service if your reasonably good on the mechanical front.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Dec 2017
    wandin nth vic
    Hi Lee
    I have just finished repairing my electric park brake. Like yours , mine sounded like it was grinding itself to pieces . The hardest part is Removing the unit from the Vehicle as You need to Disconnect the cables from the shoes. Once the unit is out remove cover , most likely you will find the threaded shaft attached to the left hand cable will be at full travel and bound up on the splined shaft. The shocking noise you hear is the clutch system in the plastic gears in the gearbox . Yes plastic. Once you have freed the thread you will need to unwind most of the way. This problem stems from brake shoes being out of adjustment allowing cables to travel too far. Mine was on a RRS 2007 but i think they are a D3 anyhow.
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    Quote Originally Posted by Discolns View Post
    Hi all,
    I bought this recently
    Land Rover Discovery 3 Upper Tailgate Actuator FUG500010 - 4WD Industries
    And it was about half an hour to change. I also changed the lock that it opens in the lower tailgate at the same time as mine was old, worn and dirty.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Ocean Reef WA
    My EPB failed recently. 2016 D4 and the noise it made was horrible. Luckily still under warranty so changed by the stealer.... electronic module failure or something.
    I never use the "drive through" facility always preferring to manually operate the thing so there shouldn't have been much shoe wear.
    Why do the manufacturers insist on "inventing" these crap things to save the lazy driver from having to do anything?
    AlanH.
    Sep 2014
    Baldivis WA
    Just replaced all four rotors and pads on my D4, whilst the rotors were off I cleaned out, lubed and adjusted the rear brake shoes of the EPB. I NEVER use the drive away function, ALWAYS engage/disengage when standing still. The amount of brake dust and dirt inside was still considerable. Used compressed air to clean it out and liberal amounts of brake cleaner. Then used lithium grease on the pivot points and on the adjuster.
    All sweet, the EPB engages properly (shoes set slightly closer to the drum no noise and dead easy to adjust. With the wheels off and car on stands, I applied and released the EPB a couple of times after cleaning and putting the new rotors on, then doing the fine adjustment with the transmission in neutral, adjusting until no drag felt on the rotor hub when the EPB is OFF.
    Ocean Reef WA
    Excellent post Eric. Getting to do my own maintenance on the EPB is one of those things I will be doing in the future. There are some things of course I'll leave to the independent as he's reliable but I do like doing my own thing where possible.
    Cheers.
    AlanH.
    Oct 2012
    Don’t forget the water hose in the adjustment hole technique for a brake dust and crud wash out. Works a treat.
    Jul 2012
    Perth- South of the River
    Quote Originally Posted by PerthDisco View Post
    As straight forward as it sounds? Wheel off. Take out small plastic cap/plug. Stick hose in/over hole and hose?
    Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
    Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
