Results 1 to 10 of 21
Thread: Wheel nut torque to wide versus thin tyres
    Sep 2018
    Travancore
    www.aulro.com/afvb/l319-discovery-3-and-4-a/263845-i-bought-torque-wrench-6.html
    This picture and explanation (from here: Dynamics - Pressure) using knives is pretty good for pressure / force relationship.
    David
    Was looking up wheel nut torque and whether my ryobi 18v rattle is a worthwhile investment - too powerful at 160Nm it seems ahaa ahhha ha
    But in the discussion is something many have alluded to re the choice of tyres, thin give more pressure to terra firma this would seem to prove. Therefore I would surmise to cut through loose surfaces down to the base rock so to speak and gain greater traction the thins win!!! Still must say the fatty ones do look tough - even if they may look tuff stuck in the mud!
    MMMMM
    Arty
    Torres Straits
    Tall and thin profile tyres also have the advantage in soft surfaces in that their surface area is long with a narrow width. Therefore less resistance against the leading edge moving forward.
    Newer vehicles compensate for their fat tyres with lots more power. Current SUV type Fourbies get away with fat tyres (which look sexy) by having a zillion kilowatts.
    WRT to your 18V rattler, just buy a torque extension bar in the range you need for your wheel nuts, spin em off at full noise, apply using the torque bar
    Kincrome - Torque Extension Bar Set 10 Piece 1/2" Square Drive | Sockets, Socket Sets & Acces (174) - Kincrome Australia Pty Ltd
    S
    Apr 2016
    Country Vic.
    which Ryobi gun do you have(or are you looking to buy one)?
    I have the 181W model .. works OK, nowhere near as strong as say a Makita(or other high quality, super expensive brand/models), but for us mere mortals .. strong enough.
    The 181W does up to 360Nm, but remember they have various speeds, which then lower the total torque they apply.
    eg. can't remember the exact specs, but at speed 3 mine supposedly does 360N, speed 2 about 200-ish, and at speed 1 around 100-ish too. Can't remember, manual and box got recycled ages ago!
    Also got a torque tube set too a while back .. not so much for the wheel nuts, but it's handy to have for them too.
    So what I do is leave the 110Nm torque tube on the extending bar I have in the D1 for the wheel nuts. Without any extension tube, it's a pain to use extension bar as a wheel brace due to it's closeness to the tyre.
    So given that I need an extension bar, may as well use a torque tube.
    They work good, you can easily feel when they start to flex .. easy peasy stuff.
    They're quite accurate too, used my torque wrench to estimate how tight they get(and it will vary, as you need to include human error) but between 100 and 120Nm is what I seem to get from the 110Nm tube.
    The Kingchrome torque tube set was wayyyy too exxy as an investment, I found a set(of 4) at Nightgales(in Laverton, if you don't know them) about $70 or so.
    As for the investment value .. probably high. I've used mine for much more than just auto stuff ... always use it to undo wheel nuts, use it on low speed to do them up after all nuts have been started on their threads.
    Recently tho, I'm building my shed, which involves "half a million" nuts and bolts, way too many of these for the footings with long threads. Couldn't imagine having to do them the old way, with a ratcheting wrench.
    I reckon the speed savings using the impact wrench over doign them manually will save me at least an hour or so ... just on the footings nuts and dynabolts(about 24 all up).
    The box of nuts and bolts I need for the frame are both marked 220 and 240 respectively, makes about 400+ all up for all of the columns and beams and gables and stuff.
    Having to do them all by hand(even tho they're short) is going to be a pain. rattle gun and the 3/8's cordless wrench I also have will save me hours of tedium.
    investment value .. IMO .. very high.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Feb 2011
    Hobart, Tasmania, Australia
    There’s a bazillion articles and arguments on fat versus thin tyres. Sometimes it also depends on what you can access. For example in 33” I have the choice of my currently 285/75R16 (fatties) or 255/85R16 (thinnies) but the type range and availability in one is far broader and superior to the other that it’s not the size determining my choice.
    Personally, I’d not use the rattle gun for torquing up the wheel nuts - they’re find for undoing. A torque wrench set to 140NM rather.
    Jul 2011
    Yarrawonga, Vic
    interesting, I recently changed from Kumho MT to a slightly skinnier profile road pattern AT tyres for my Electric Series in the interests of getting less rolling resistance and a quieter ride.
    From Kumho 225/75r16 MT to Evergreen ERS89 215/85r16
    No difference noted in kwh/km after a few hundred km , but I tell you what - they are noticeably better off road esp in mud, I always knew skinnier was better but I thought the more aggressive tread of MT's played more of a part. I won't be wasting $$ on MT's again.
    NPG Guest
    Unlike pressure, friction does not depend on the contact surface area but on the coefficient of friction between the 2 surfaces and the force exerted downwards. Traction on the other hand refers to the grip of the tyre with the road surface, where 2 more factors are involved - the adhesion forces (i.e. the bonding between the rubber and the road surface) and the mechanical interlocking as the tyre deforms against the road surface. All things being equal, as the contact surface area increases, so do adhesion and mechanical interlocking, meaning that the wider the tyres, the better the grip (and unfortunately the higher the fuel consumption).
    Sep 2018
    Travancore
    Ryobi Rid 1801 2017
    Purchased this second hand a while ago and Ryobi reckons its 160Nm which exceeds the 140Nm Land Rover recommend but well within the ball park allowing for boasting by the company.Will need to be sure they at least do 140 so will have to get this checked insitu.
    As I am looking at having a set of HT on the D2 for daily driving and having just lucked a set of 5 * 265 75 16's Bridgstone Dueller AT's at roughly 80% for $115 will not worry too much about muddies yet (just had hell getting these fitted as the front alloys bonded nicely to hubs, no way could it have done on the side of the road!!!!) and have 235 80's on the TDi 300, both nominally 32's but these are an inch wider and a hell of a lot more rubber on road versus the space of 235 muddy.
    At first view it looked the tyres would rub but even on full lock nothing, nice!
    But in looking to change over the wheels for off road purposes, the idea of changing 25 wheel nuts by hand seems over the top, hence the buying of a rattle gun as well as for screw in tent pegs. The shop used the makita but will loosen these off and rattle them to my max so to speak.
    Have never seen those bars before, do they have some form of ratchet or slip disc?
    The need for horsepower, well, lets say a standard Td5 should have 335's standard then shouldn't they?
    Arty
    Sep 2018
    Travancore
    Pressure versus adhesion
    Absolutely but as any F1 driver will tell you, the force of the tyre into the tarmac makes all the difference hence all the down force of the wings etc. The use of different compounds is a variable as of course is width. But ultimately it is the force down that makes the difference. No conclusion of course which is best just that all factors are important and I think as Goingbush says the variables are many and which is best is not necessarily looking at one area of the equation in the simple scenario such as wider is better grip which does not take into account how hard the thin tyre is being pushed into the surface and therefore requiring more pressure to elicit sideways movement or loss of grip against a wide tyre with very little pressure on the surface that could easily (relatively of course) lose grip.
    Maybe if you have wider tyres, just load up with more kilos LOL
    Sep 2018
    Travancore
    Big tyrers stilll lok tuf
    Sorry for the spelling joke, it is Tuesday
    Apr 2016
    Country Vic.
    Quote Originally Posted by RRT View Post
    The torque tubes?
    If so, no. They just twist as you use them(both tight and loosen).
    Each tube is successively thinner/thicker .. thin = low torque, thick = higher torque.
    On my set, min is 90Nm.
    You can tighten more, as it twists .. or flexes, it still tightens.
    So that is, if I use the 90 to do the ~100 that the wheel nuts need, I can keep going past it's twist point.
    The idea is that you tighten(using the tube) and then you feel it twist more than tighten.
    Kind'a hard to describe, but makes sense in use. That is, you feel it(ie. some human error is going to be involved)
    Can't remember the exact wheel nut torque, but I think it's 100Nm, so I chose the 110 tube to keep in the car with the extending ratchet.
    Idea of this is I can't see much difference between 100 and 110.
    But if the nuts tighten over time, if I have the 90 tube, it may not be strong enough of the nuts have tightened to say 160Nm, or as you sometimes enocounter .. the wheel changing monkey at the tyre store used the dugga-dugga gun at 1000Nm or something (not uncommon).
    I still usually have a normal extension in my socket set, but a PITA to get too in the tool box.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
