Results 1 to 10 of 29
Thread: 20”wheels L405
    Oct 2012
    20”wheels L405
    Can anyone confirm please if I should be looking for 47 or 53 offset wheels . I’m wanting to replace the 21” with 20” so as to fit 55 profile tyres on My L405 SDV8
    NSW SW Slopes
    53 was for the original L320 RRS, D3, D4 etc where the rims were set in further than on the L405/L494.
    Oct 2012
    Thanks Graeme ... I’m bit thick so want to be sure before parting with $$$ , are you saying I need 47 Offset . 20”wheels L405
    NSW SW Slopes
    I had in mind that the L405/L494 offset was 45 but perhaps that's just my not recalling exactly. The rims will have a part number that can be checked for applicability.
    Edit: The standard 20"x8.5" rim for the MY13 L405 ALY72245U20/72265 Range Rover Wheel Silver #LR037745
    has 47mm offset.
    Oct 2012
    has 47mm offset.
    Thanks Graeme
    The rims I’m looking at are off a 2014 RR Sport & are 47offset so I’ll inspect them and all going well part with some more cash . Cheers
    NSW SW Slopes
    I just sent you a msg.
    Oct 2012
    L405 has TMPS - 20" Wheels Dont
    Ive now bought a 2nd hand set of 20" wheels off a L494 Sport (TICK) and will probably fit NITTO 275/55R20 tyres (TICK). The L405 Autobiography & current 21" wheels have TMPS but the 20" wheels don't have TPMS. Do I need to have the dealer Turn Off TPMS or will the car just ignore it as it wont be able communicate with wheel sensors. I do have an IIDTool but hesitate to get in too deep with it.
    Dec 2009
    Ranelagh, Tasmania
    Quote Originally Posted by orangepop View Post
    You can move the TPMS senders over to the new wheels or buy some more. If you don’t have senders in the wheels it won’t matter as the TPMS should just ignore it. It did on my D4.
    You bought the correct wheels. 20”wheels L405
    As for the tyres, Nittos probably wouldn’t be my first choice but they aren’t bad.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Oct 2012
    Thanks , I’m not locked into Nitto but have seen a few posts suggesting they are good. What would you suggest?
    NSW SW Slopes
    My Pirelli AT+ in the same size are quiet. The AT+ has LI 113 whereas the TG has 117 although neither is classified as LT.
