Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: When is the EPB applied?
    Dec 2011
    Adelaide
    142.79 MB
    I was looking at a few past and recent threads on the EPB, and, touch wood, I've not had issues (yet!)
    But I seem to recall comments made in the past that whenever the car is put into Park, the EPB is applied.
    Then I've read threads that it isn't!!!!
    I hardly use mine for anything unless it is a steep hill, and I never use it in the "drive off" mode.
    Does anyone know for sure how this thing works, and does it do any secret applying when we don't expect it.
    Just curious.
    Alan
    2012 L320 Range Rover Sport Fuji White
    REMLR 012
    No 5 Trailer ARN 177-295
    2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
    SOLD Engineers Trailer - no id
    SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
    SOLD 4MP COY Series 3 FFR 30-209
    You haven't said what model - so I assume the one in your signature.
    In that vintage the EPB does not come on when you go into park - you manually have to do it - the same as any old car.
    I believe that in later models (D4?) the park brakes does come on.
    Jun 2018
    Tamworth
    Hi Alan. My understanding is that in an auto it is only coming on when you apply it (that's how my 05 auto works).The manuals (I believe) can come on automatically as part of a hill start drive off mode.
    The previous owner of mine never used it or maintained it which lead to it seizing within 4 hours of me buying the car.
    I replaced it and service every now and again with no issues. Bodsys brake bible is great for how tos and to let you know how to give it a quick (15 minute) adjust.
    If you're an irregular user I'd recommend watching a video on how to manually release should it ever jam on you. The tools are all in the back and it takes 30 seconds once you know what to pull.
    Didn't really answer your question but after my run it's one of the few things on this car I'm up on.
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by Parso View Post
    Comes on when you take the key out unless you hold the switch down as you remove the key.
    I've only forgotten to take it off once, and the drive-off function was quite noticeable. With a car that heavy you don't need to use it for a hill start. You have about a fortnight from the time you get off the brake until the time you get off the clutch before it starts rolling backwards.
    Dec 2011
    Adelaide
    142.79 MB
    Quote Originally Posted by 101RRS View Post
    Oops, sorry - yes, D3 Auto.
    REMLR 012
    Feb 2011
    Hobart, Tasmania, Australia
    Our MY12 D4 doesn't automatically apply the EPB when putting the vehicle in park. I know this because our switch was recently faulty and would not disengaged the EPB so the vehicle was driven for a week and a bit without using the EPB (because of the complications in disengaging it). It was still parked in Park on the flat and this did not engage the EPB. New switch and it's fully functional again but highlights the issue someone will experience one day when they have the same fault but in a later model that automatically applies it...
    Sep 2014
    Baldivis WA
    MY11 D4 have to lift the button to engage, regardless whether in gear or park. 6spd auto box. Only automatically disengages "drive away function" but that puts excessive wear and tear on what is the park brake.
    I always stop the car, put it in neutral and access height, apply the park brake, release the footbrake pedal, then put it in park and turn off engine. This prevents the transmission clutch plates being preloaded. The EPB is more than capable to hold the car on an incline.
    LRD414's Avatar
    Oct 2014
    This is correct but not until the last year or two.
    Mine is an MY14 and the EPB does not apply automatically.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    1.13 MB
    Mine is a MY16 D4 and EPB does not set automatically, which is good because it's currently stuffed and hasn't been used for months. What does happen is it goes into Park when you turn the car off if it's in another gear.
    Rod
    D4 MY16 5 seat TDV6 - LLAMS, Custom Drawers, OL Bar, Toyo Open Country, GOE Rims, Lithium DBS, eDiff, OA Long Range Tank, GAP Tool, Tracklander rack, Mitch Hitch, TPMS & Safari Snorkel
    Jul 2012
    Perth- South of the River
    Quote Originally Posted by rocket rod View Post
    X2 for above. Possibly the MY16.5?
    Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
    Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
