Thread: Rear Rego Plate
    Oct 2014
    Northern NSW.Australia
    Rear Rego Plate
    Hi.
    Where do NSW Landy owners mount the rear plate.
    Seem only one size and two long, on either side of the tube door.
    Intrested to see pics.
    Not quite at that point Gav.
    Got a quote from Shannon's. $575
    Heading into NRMA
    Full comp, agreed value $20.000 pay out and still retain damaged vehicle.
    Any others to try.
    Thank You.
    whitehillbilly
    Almost all Series Landrovers sold in Australia came with the number plate mounted on a bracket hinged to the centre rib on the tailgate so it shows when travelling with the tailgate down.
    If you are prepared to allow half an inch of the plate to be covered by the seal area of the tailgate it will fit either side, which is what I have on my current 2a.
    This is where the plate was on my Series 3.
    Oct 2014
    Thanks.
    A bit of 'trimming' to fit ?
    whitehillbilly
    DiscoMick Guest
    Is it legal to trim a number plate?
    Oct 2014
    Probably not
    I had a Auxiliary plate on my Mitsy motor bike carrier.
    That size would be perfect, But Probably not legal.
    whitehillbilly
    On the 2a in my picture above, about half an inch of the LH edge of the plate is covered when the tailgate is closed. Been like that for over 25 years without a peep from anyone.
    But the factory supplied solution is the hinged tailgate carrier shown on the Series 1.
    Of course the other solution is that of the optional (and costly) NSW smaller plates.
    Sep 2012
    Westlake ,brisbane
    I mounted the no plate on my 80" under the L/ H tail light I also made one of the ramps they use on the Defenders as the plate sticks out the side about 25mm , stops people walking into the plate & bending it. I will post up a photo tomorrow when I get back from my trip & can use my desk top.
    Sep 2012
    Westlake ,brisbane
    OK back from trip to Narrabri. These are what I have done. 20190612_083347.jpg20190612_083357.jpg20190612_083420.jpg20190612_083431.jpgIMAG2200.jpg
    Sorry about the photo's being on there side bit since I have been taking photo's with Samsung phone they always post on here sideways. I didn't attach it to the side panel didn't want to put any holes in the side but did stick some felt on the bracket so it wouldn't scratch the paint. One day when I win Lotto I will get Special Interest Plates that will fit but @ $2500 can not justify it now.
    Irymple, Victoria, Australia
    The number plates on my series vehicles all get a smidge trimmed off the edge so that they fit, then they are attached to the right of the tailgate.
    As per the Vicroads requirement, they are all clearly visible at a distance of twenty meters.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
