Thread: RRS or D4 steering wheel clunky rattle when driving slow
    Towcar Guest
    Hi Guys,
    Chasing a noise in my steering column. Its a low pitch rattle, the car is well maintained, 175kms, new struts compressor LCA etc a year ago.
    Recently inspected and specialist couldn't find anything wrong with it. Although this noise is only heard when you hit a speed bump etc, at low speed. I can feel it through the column...been here for about 2 months
    YouTube
    Any help would be appreciated
    Jeremy
    Sep 2014
    Baldivis WA
    Front sway bar bushes?
    Towcar Guest
    They are ok, I can feel it through the column, very annoying, may need a 2nd opinion on this
    Sep 2014
    Baldivis WA
    Have you checked the power steering fluid level? It gets pretty dirty, a full flush and top up with new fluid might make a difference. Otherwise it could be the steeringbox itself, especially if you're getting shudder through the column.
    Oct 2014
    A uni joint in the lower steering column is known to fail/seize, Disco3 thread linked below:
    DISCO3.CO.UK - View topic - Steering stiff - New lower column fitted with guide
    Other possibility would be tie rods ends.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
