Results 1 to 6 of 6
Thread: Marine Battery for Defender?
    Scarborough, QLD
    I'm looking to replace my cranking battery and auxiliary battery. My current cranker is a 4yo Caterpillar battery, which is getting a bit tired. The auxiliary is a Century marine battery of the same age, and is buggered. Any reason why I shouldn't/should go another marine battery?
    Any other battery suggestions?
    May 2014
    Tamworth NSW
    I have 2x Optima 'Blue tops' in the group 34 size. Works for me. They are a hybrid style battery - a mix of deep cycle and cranking
    The blue tops are the same specs as the yellow top, just with additional threaded post terminals for additional accessories (above and beyond the SAE posts).
    -Mitch
    'El Burro' 2012 Defender 90.
    Kilmore, VIC
    106.38 MB
    I have the same in the D1 (2x blue tops). Seems to work a treat. The cranking battery is about a decade old and still working like a new one. The aux is only a couple of years old... so far.
    DiscoClax
    '94 D1 3dr Aegean Blue - 300ci stroker RV8, 4HP24 & Compushift, usual bar-work, various APT gear, 235/85 M/Ts, 3deg arms, Detroit lockers, $$$$, etc.
    '08 RRS TDV8 Rimini Red - 285/60R18 Falken AT3Ws, Rock slider-steps, APT full under-protection, Mitch Hitch, Tradesman rack, Traxide DBS, Gap IID
    Scarborough, QLD
    I decided to just replace my cranker with a Supercharge MF95D31R, and will drop a deep cycle AGM in as the auxiliary.
    99.87 MB
    Been using Blue Top for about the last 15 years - they're a great battery.
    Slunnie
    DiscoMick Guest
    Quote Originally Posted by Ranga View Post
    Good move. Starting and auxiliary batteries are different.
    Starters give a big charge to start and do very little else. They have thin walls. They recharge fast.
    Auxiliary batteries have thicker walls and are designed to give a slow discharge. They recharge more slowly.
    Using them for the wrong purpose damages them.
