Battery Cell dies during warranty for the second time - 2 questions arise?
2 Questions are:
1.) Are Disco 3/4 Battery killers?
2.) Is it worth keeping 2 cranking Batteries up front if not running accessories requiring the deep cycle second battery.
I have a Traxide Dual Battery system with MF88H and Amptech deep cycle in the second bay?
2 Explain further...
Love a brand of Battery with a great warranty period of 36 months, always used them and put in every car I have owned for years. Extremely reliable and always have lasted well past their warranty term.
I have just bought another for the discovery 3 V8 HSE as the warranty term is believed to be out of date (can't find the original receipt, but did have it one time it would seem, otherwise they would not have replaced it under warranty 18 months ago.) as the second battery now died.
Both warranty claims have had the same characteristics - Battery working well and then just drop a cell to allow max 11 volts - not enough to start the beast.
The Battery seller mentioned that its very rare, but suggested that if its going to happen it will on LR Discovery as they have lots of stuff going on.
They also mentioned that that have a bloke that has a 200 series Landcruiser and only gets 24 months out of a battery and it dies - no matter the brand, again seems to have something to do with the specific vehicle (not the Brand of vehicle or Battery)?.
Have others experienced High Battery wear and or cell failure in the D3/4
Second Batter as cranking not deep cycle.
Also I was thinking that it may be a good idea to avoid being left stranded to Get a second 'cranking' battery in the second bay rather than the Deep cycle as I don't run 'accessories' (fridges n stuff) as such, but have a cable through sill to an anderson plug at the back of the vehicle to power trailer Brakes for the Shark Cat trailer.
My thoughts are if I had another 'cell' die in the cranking Battery - I would be able to use a jumper leads from the second battery bay, to temporarily override the dead 11 volt battery (main cranker) and get a 'start' again and on my way.
I did try to jump from the Amptech as an experiment and it didn't have the 'grunt' to start the motor.
The trouble with the autos is they wont start with a roll start if remote and no other vehicles.. so thinking a second smaller cranking Battery (to fit the 2nd bay) would be better for my purposes than the amptech deep cycle and at the same time provide the abilty to jump the car if ever required.
I would assume the Traxide would perform the same as current except may drain the second battery (if used to power a fridge )- I am aware it would damage the second battery if voltage drops too low.
Reason: wrong number disco
D3 2005 4.4 V8 HSE java Black.Alpine Roof,Alpaca Leather 7seat,LRSat Nav,E diff,Bi Xenon.Hi-Ice et.voice control.Bluetooth Phone.Kaymar rearbar.Roofrails and Racks.18rims.Traxide Dual Battery towpoint Anderson plug. Xenon 4300k Hbeam.10wled450lightbar.
