Results 1 to 3 of 3
Thread: Extended mode height
    The online MY18 manual states ...........Once the extended mode height is achieved, additional lifting can be requested, if required. Press the brake pedal to maintain control of the vehicle. Press the up button (1) for longer than 3 seconds.
    Nowhere can I find the actual height for extended mode nor the additional height although I'm sure I've seen this somewhere?????
    Pennant Hills, Sydney
    will try that tomorrow
    disco seriesII mods so far:-bullbar,hyd winch,
    detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
    In the event of nuclear war,Disregard this message
    Oct 2011
    Hunter Valley
    Don't forget to put it in extended mode first. You can do this by going into off-road mode, then placing the jack under the car and lower the car again. It will detect an obstruction and then go into extended mode. From there you can get into super-extended mode as described above.
    Ron
    2016 D4 TDV6 Corris Grey
    2018 D5 TD6 SE Silicon Silver - gone
    2011 D4 TDV6 2.7 Indus Silver - gone
    IIDTool BT
