Results 1 to 6 of 6
Thread: Disco 4 small brackets
    captainjsw Guest
    Greetings fellow Land Rover owners.
    I have rebuilt a SDV6 3.0 - new crankshaft and shells etc, I did take a large number of photos, but cannot work out where these brackets go. Somewhere on the rear of the engine I thought near the rear belt but just cannot work out where they go, so was wondering if anyone who had stripped a motor down knew.
    Also, does anyone know what the large steel weight are at the back of the cars chassis - just out of interest
    IMG_2574 (Large).jpgIMG_2575 (Large).jpgIMG_2576 (Large).jpgIMG_2573 (Large).jpg
    Dec 2009
    Baldivis WA
    I can’t help with the brackets, but the large swinging weights at the rear are to reduce NVH. They are also know as Disco Balls.
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Mar 2016
    Quote Originally Posted by kelvo View Post
    As above. They are harmonic balancers essentially. The chassis will resonate at certain frequencies and these weights help to stop it.
    2007 Audi RS4 (B7)
    Sep 2014
    Baldivis WA
    Those brackets look like the ones that carry the steel cross over pipe over and behind the engine, over the HPFP. they also hold numerous cables and hoses up off the manifolds etc.
    Jul 2017
    Victoria
    I have a 2015 with a spun bearing, I would be very interested to hear how you engine goes after the rebuild.
    Nov 2019
    Hi guys, I have a 2011 sdv6 that has just broken the crank. Just out of interest wondering if anyone has had there block damaged beyond repair and
    if you where able to have the bearing line bored and new bearings and cranks fitted. I was looking at the new forged cranks and the new high volume
    oil pump (Extra 19.5 pump made in russia).
