Results 1 to 10 of 18
Thread: Tow Ball Weight L405
    Oct 2012
    Can anyone confirm what the maximum allowable tow ball weight (nose weight) is for a L405 please.
    NSW SW Slopes
    Australian specs for MY2016 show 350kg except for the hybrid and 5.0 SC which are 300kg.
    Attached Files Attached Files
    Dec 2011
    Forrestfield WA
    My manual says:
    "Australia only: Tow Ball nose weight must be a minimum of 7% of gross caravan/trailer weight, up to a maximum of 350kg."
    Bob
    Dec 2009
    Ranelagh, Tasmania
    The V8 SC you refer to is the SVR, the standard V8SC is 350kg.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Oct 2012
    Hmmmmmm .. that’s what I believed however the WESTFALIA sticker on the tow bar of my 2016 SDV8 Autobiography says “Max Vert Load S200kg” which I assume is the nose weight? I phoned the dealer and asked for the spec on a new bar & was told max weight 250kg and that there was only 1 model ... I thought there may be a light & a heavy duty bar.
    Oct 2012
    Quote Originally Posted by BobD View Post
    My manual says:
    BobD, my owners handbooks says the same on page 115. The paragraph above mentions the 200kg & 250kg . Hopefully the sticker relates only to the UK spec. I would be interested to know if anyone has a sticker stating 350kg on their L405 tow bar.
    Queensland
    Mine same as yours "S200"...on the actual tow bar (had never noticed (read: crawled under there"!!)
    L405, Vogue SE, 4.4SDV8, 8 speed, Rear e-diff
    NSW SW Slopes
    How much weight is S200? Seems more like referring to a standard rather than actual kg.
    Queensland
    Good point!
    NSW SW Slopes
    I suspect that it's an AU approval code obtained by JLRA or perhaps the tow-bar manufacturer's special approval code for AU use.
