Results 1 to 3 of 3
Thread: Best terminals
    Scarborough, QLD
    Best terminals
    Which terminals and supplier do you use? I usually go for the Narva, but was wondering if anyone knew of a better option.
    Aug 2010
    Sunbury, VIC
    Narva are fine, Hella are good too, but not as readily available (well not around here anyway). OEX terminals available from Ashdowns are also good IMO, but generally you’ll be buying a box full rather than a few at a time from them. At work they use Wurth stuff - again, it’s fine, but unless you have decent buying power, they can be expensive.
    Avoid the fleabay specials, Amazon or other cheap stuff - the plastic is quite brittle on some of these and there isn’t as much metal in them either.
    Sep 2010
    Moe, Victoria
    Things I use often I buy in bulk at RS Components - no complaints re quality. I find Anderson stuff is cheaper elsewhere - I'm agnostic to suppliers and buy on price being careful to ensure its genuine.
