Results 1 to 9 of 9
Thread: Cooper Discoverer AT3 275/55/20 120S 10 ply rated
    Queensland
    All
    anyone had experience with the Cooper Discoverer AT3 in 275/55/20 - 10 ply rated? (120S)
    Chris
    2 New Cooper Discoverer A/T3 XLT All Terrain tires - LT275/55R20 LRE 10PLY Rated | eBay
    L405, Vogue SE, 4.4SDV8, 8 speed, Rear e-diff
    Kingston, Tassie, OZ.
    Quote Originally Posted by CSBrisie View Post
    All
    Chris
    Chris they are almost 32". Gearing will be pretty high and guard clearance may be an issue..?
    NSW SW Slopes
    Is the L405's diff ratio as high as the 4.4 L322? I suspect that it is lower due to 31" tyres rather than 30" on the L322.
    Edit: My 4.4 L322's ratio is 2.76 and the L405/L494 appears to be 2.73 from an ebay advert, so slightly higher geared than the L322.
    Hmm - 4 different diff part numbers for 4 different engines for the MY13 L405 so the ebay advert is short on information, although being such high ratio it is most likely for the 4.4.
    The huge drop in vehicle weight would almost negate the need to lower or alter any gearing, the last SDV8 I drove felt much more sprightly than mine...
    NSW SW Slopes
    The engine is a little up-spec'd on ours too.
    Queensland
    Thanks All - also looking at Pirelli, and BFG (knowing Graeme has experienced both Cooper Discoverer AT3 275/55/20 120S 10 ply ratedCooper Discoverer AT3 275/55/20 120S 10 ply rated)
    NSW SW Slopes
    I'm still waiting to see how my AT+ survive on sharp rocks and having only travelled 7K they have along way to go to prove themselves, but the tread is unmarked from 80-100 kph travel over the coarse rocks poking up out of my lane and I really appreciate their quietness and handling, not that the BFG's didn't handle well.
    Pirelli still haven't invoiced my supplier for the replacement for the one pierced through the upper sidewall by a sharp wedge of steel pipe picked-up just outside my gate and I understand that Pirelli now have some sort of replacement policy for these tyres.
    Dec 2011
    Forrestfield WA
    All
    Chris
    275/55/20 are fine on an L405. There are no clearance issues and they fit the spare wheel well with no modifications. No noticeable difference in performance or towing for me and mine is a TDV6. The standard tyres are 255/55/20, so not a huge difference in diameter.
    285/55/20 will also fit but the spare will be too high and the spare wheel cover that forms the floor of the boot will not fit and will be lifted above its correct level.
    Bob
    Oct 2012
    I was surprised to see the local tip weigh bridge display 2.7 +... something the other day when I just drove in to get an idea of weight before I hooked up the van. Car was empty apart from me (75kg) & 105 ltrs of fuel. It’s an Autobiography but all the extra stuff shouldn’t add that much to weight. Has anyone else weighed their L405.
