Results 1 to 10 of 23
Thread: Defender Steel Rims on a Discovery?
    96DiscoV8 Guest
    Is it posable to run Defender 110 rims on my 96 Discovery V8i? I have alloy's at this moment but want the Defender Rims now how ever I have been told that in doing that I will upset the whole drive-train and possibly damage it too not to mention taking out the guards as well. Is this true? :?:
    I can't see why you would not be able to use Defender rims nor why it would damage the Disco. Who gave you the info?
    The diameter and offset on a Defender rim is identical to the Disco 1 - check the markings. The Disco will have stamped upon it something like 7Jx16x33, the Defender 5.5x16x33.
    The 16 = diameter in inches, the 33 the offset in mm, the 7 or 5.5 is the width.
    Defender rims were used on Camel Trophy Discos. Disco rims will fit Defenders.
    Ron
    96DiscoV8 Guest
    Ron
    My mechanic did, he also said in order to fit these rims I would have to left the body by 1 or 2 inch's and put lower diff gear ratios in them.
    Think your mechanic is talking about tyres. Defender run larger tyres than Disco, rim size is the same.
    Simon
    Jul 2003
    Re: Ron
    Welcome
    Ron is right.
    Defender drivers use disco wheels.
    And providing that you don't exceed a total of 30" total diameter of the wheel/tyre combination you won't notice the difference
    Can I suggest that you change your mechanic :wink: and spend some more time here
    Mahn England
    Ex 300Tdi Disco:
    Nanny state UK...
    Defender rims will be fine on a Disco. As mentioned, your mechanic was probably talking about tyre sizes.
    If you fit wider tyres, you'll have to adjust the steering stops... Otherwise the front tyres will rub on the radius arms at full lock.
    You can fit slightly larger tyres on the Disco without a lift but you'll have to trim a tiny 'wedge' from the rear quarter pannel (it's what they did on the Camel Trophy). Defender sized tyres will require a body lift though.
    HTH
    Mark.
    Nanny state UK...
    Re: Ron
    Another option is to change the transfer box instead of diff ratios. Although the Defender & Disco have the same transfer box... The Disco has higher ratios.
    Just a thought....
    Mark.
    Re: Ron
    BTW, the diff ratios on a Defender are the same as a Disco 1, a Rangie classic, a Disco 2, and a P38A RR. However, the transfer case ratio may vary.
    Ron
    May 2003
    On The Road
    you guys are great.
    this HAD to of helped 96DiscoV8 8)
    Hi
    I have defender wheels and tyres 7.15x 16, I have cut the rear quarter panel on the back edge by approx 30mm . as i have 1 inch wheel spacers I have raised the suspension by 2 inches.
    forget about the gear ratios.
    I was going to put a photo on , but i dont know how :?
    Richard
