Results 1 to 2 of 2
Thread: ECU speed signal resistor ohms
    Jul 2019
    Adelaide
    Hi, I have been restoring my 1990 Range Rover Classic with a 3.9V8 EFI. While tracing some wiring going to the coil, I came across a resistor that is wired into into the feed to the ECU (input 39) as engine speed signal from the negative terminal on the coil. The specifications state that it is a 6.8K ohm resistor. Mine is reading 7.42K ohms.
    Does anyone know what effect if any this would have on the ECU?
    Geoff
    Dec 2014
    FNQ
    it's within a 10% tolerance for a 6.8KΩ resistor.
    the actual resistance of a 6.8kΩ ± 10% resistor will have its value as being read somewhere between 6.12kΩ and 7.48kΩ.
    Roads?.. Where we're going, we don't need roads...
    MY92 RRC 3.9 Ardennes Green
    MY93 RRC LSE 300tdi/R380/LT230 British Racing Green
    MY99 D2 V8 Kinversand
