Results 1 to 10 of 27
Thread: K & N FILTERS
    Frankston in VIC
    K & N FILTERS
    Hi Guys,
    Have put a new K&N Filter into my 300 Tdi last week ,and found that it's the best thing I could have done for this motor, e.g. when I start it up in the mornings now ,it doesn't make the usual sounds any more,motor heats up more quicker now which means no driving up the road in slow mode like be4 and when you have a teen on broad saying I'm late 4 school ,but you have plenty of time to get there ! haha ! . there's this hill that I climb on the road that I use to going at 80 k's be4 it changed down to 3 gear (auto) ,but still only 80, now crusie at 90 k's and no gear change , :-) . So guys is it because more air flow into motor that making more power and torque ? or it something else, well I'm happy
    cheers4now alex
    P.S. just filled tank up , yet to fine out the km's per tank ,normally 820 k per my standed D1 tank :-)
    Jul 2003
    The general view here and elsewhere is that the improved air flow achieved with oiled filters has a down side: increased intake of dust = increased engine wear
    http://www.outerlimits4x4.com/PHP_Modules/...pic.php't=65854
    http://home.usadatanet.net/~jbplock/ISO5011/SPICER.htm
    But if you stay on sealed roads the risk is reduced.
    Mahn England
    Ex 300Tdi Disco:
    Nov 2005
    Maudsland, QLD
    I've got a K & N on the Rangie and have fond that it keeps the dust out just as well as the stock paper filter and I also repels water!!!
    2023 Defender 130 D300
    SOLD - 2010 Discovery 4 V8
    SOLD - 2008 Range Rover Vogue L322 TDV8
    SOLD - 2006 Range Rover Sport L320 TDV6
    SOLD - 2002 Range Rover L322 TD6
    SOLD - 2002 Discovery 2 TD5
    SOLD - 1997 Range Rover 4.6 HSE
    SOLD - 1999 Range Rover 4.0 SE
    I thought oiled filters were bad news for the MAF sensor.
    Ron
    Warburton, Victoria
    K&N are one of the best around due to the filtration... most dont filter as welll...
    Keep us informed of the progress of it.
    I run Std filters and a Pre filter in the Snorkel to stop bad dust on convoys.....
    Melbourne - Eastern sector
    i used to think k&N were good too untill i read this -
    I sold mine and now use OE filters in all my cars
    Mick
    Avoca Beach
    You are dreamimg. Its called the halo effect.
    A filter could not effect warm up .
    maybe better air flow only if if you had never changed your standard filter at theexpense of poor filtration..
    Regards Philip A
    Frankston in VIC
    [b]Hi Guys ,after 2 weeks of running on a full tank of fuel ,I still get 820k's per tank,more torque and power when I need it and when I used to start up with a cold motor ,no puff of smoke coming out of exhaust ,just gone!!!! cheers4now alex
    p.s. that halo effect. by PhilipA .....hmmm, I just think more air in cylinder has to make more combustion, more combustion means heat , heat warms engine block ..... hmmm
    Avoca Beach
    Altech, I have tested a Range Rover cylinder paper filter for its resistance to the air flow with a $100 Minihelic differential vacuum gauge calibrated to max 30 inches of water.
    Up to about 3/4 acceleration its resistance is NIL and at full noise on a 3.9 it is 4 inches of water which is a tiny bit. That is both the filter element and the housing. I took the vacuum reading between the filter and MAF.
    Now I havent tested a Disco panel but at low revs I am sure it would be nil unless very dirty. A diesel passes more air at max torque revs but at idle and not full torque it should be only passing a moderate amount or air.
    I have found that improved inlet air flow only gives an improvement at absolute maximum air demand eg up a hill flat aand only if the standard filter is too small. Others eg The Toyota V8 forum have tested them on dynos and found a very small improvement in power ONLY at max demand.
    Did you read the reports on K&N? I had one , and found fine dust in my MAF after a trip to Jerilderie via Wombeyan Caves. If its an 300Tdi auto with a MAF, be careful you do not foul it .
    It should do no damage on a straight mechanical 300Tdi except if you travel on dusty roads.
    You are entitled to believe in it, but show me the test results before I do.
    A reason I now do tests is that I bought a Hiclone on the advice of a friend who swore that he got 15-20% fuel economy improvement. I got zilch when I tested it to and from Sydney to Brisbane.
    Regards Philip A
    <div class='quotetop'>QUOTE(PhilipA &#064; May 18 2006, 09&#58;39 PM) Quoted post</div><div class='quotemain'>
    Altech, I have tested a Range Rover cylinder paper filter for its resistance to the air flow with a &#036;100 Minihelic differential vacuum gauge calibrated to max 30 inches of water.
    Regards Philip A
    [/b][/quote]
    Phill u shouldhave tried fuel magnets they really work.......
    for those who care the latest mythbusters aired in the us is about fuel saving devices..... afwiw non of them work&#33;&#33;&#33;
    Mick
