Results 1 to 10 of 16
Thread: Deep Sockets for Impact Wrench
    Jan 2013
    Molesworth,Tasmania
    Just purchased my first impact wrench.
    would it be more economical to buy a set of deep sockets rather than standard size? My thinking is deep will do deep and standard, whereas standard will not do both? Or is there a reason why you should only use a deep socket on a “deep” fixing?
    Apologies if I am not making much sense.
    All comments gratefully received as usual.
    cheers,
    D
    1957 88 Petrol (Chumlee)
    1960 88 Petrol (Darwin)
    1975 88 Diesel (Mutley)
    Feb 2014
    Impact sockets
    Quote Originally Posted by Dark61 View Post
    cheers,
    D
    Impact sockets are expensive so I see your problem. For that reason deep sockets are the go.
    however, I have found that in some cases the deep socket makes the overall length of the tool plus socket too long to get into some spaces ( eg Defender panhard rod bush bolts)
    i solved this by buying individual short sockets where I need to, or just use a breaker bar on a deep socket.
    Phil B
    Custodian of:
    1974 S3 swb wagon (sold)
    1978 S3 swb canvas
    48 749 '88 4x4 Perentie
    1985 County with 4BD1T
    Mar 2007
    Warwick Qld
    Mobs like Supercheap, Repco, etc usually sell impact sockets singly. Personally, I bought a set of deep sockets, then just add shorts as you need them.
    My usual technique for buying the non-name brand ones, is to go by weight. Over the past 45 years or so, I've found that (with regards to tools for heavy duty use, at least) the lower quality ones are often noticeably lighter than the "gooder" ones. YMMV
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    Jun 2016
    I bought these a couple years ago. https://www.amazon.com/TEKTON-2-Inch...gateway&sr=8-2
    They had good reviews and have held up well but I'm not using them every day.
    350RRC's Avatar
    350RRC is offline ForumSage Silver Subscriber
    I bought a cheapo set of deep impact sockets 10 years ago, maybe $25, and they've been fine. They are 'heavy'. Maybe 10mm up to 24mm.
    I've got a couple of sets of 1/2" drive shorties and the deep sockets complement them really well.
    They get used with a rattle gun and also with breaker bars and hand ratchets.
    Really handy at times for difficult access.
    DL
    Jan 2013
    Molesworth,Tasmania
    Quote Originally Posted by Phil B View Post
    I had not considered access! Thanks for the heads up.
    cheers,
    D
    Narre Warren South
    I've purchased impact sockets for particular jobs, no need to pay extra for the strength of an impact socket for day-to-day usage.
    I'm also fortunate that the Kincrome outlet shop isn't too far away so I've never paid retail. A while back I put together a set of deep sockets (not impact) in metric & imperial for $2 per socket.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    What about a set of these - Black Drive Deep Impact Metric Socket Set Car Garage Tools 35pcs 1/2" AU | eBay. You get both in the one kit.
    Not that expensive and and should do the job for a while.
    I personally have some high quality ones but I’m sure most wouldn’t want to pay what I did for those, but when I was on the tools, I used them daily so worth it back then.
    Sep 2010
    The Hills.
    152.79 MB
    It comes down to:
    1; what are you undoing? Good quality ordinary sockets will stand up to undoing wheel nuts and most ordinary nuts and bolts.
    2; what power does the impact wrench have? I have a Milwaukee 18V Fuel 3/4" drive gun. The torque is awesome. I use it with my 1/2" drive sockets often with an adaptor ( which adds to the accesibility issue ), but it would absolutely destroy them on say a 300TDi crankshaft pulley or any other high torque nut/bolt, but it's incredible. Not everyone wants or needs one of those, so what you need to buy will depend on that.
    3; single hex vs double. There are all sorts of debates around physics which I won't go into, but I prefer single hex when possible, as they seem to prevent rounding of the bolt or nut, and impact sockets are nearly universally single hex. The accessibility issue resurfaces here though, as the single hex impact sockets have thicker walls, which is a pain when there is limited room around the fastener.
    4; I guess your original question revolved around "deep" sockets though. That has no bearing on whether you have an impact gun or an ordinary ratchet or breaker bar. Deep sockets have a specific purpose, which is reach, and you are better off not using them if you don't need to.
    All that said, I reckon an impact gun, especially a cordless one, is a fantastic investment. Mobs like SuperCheap and TotalTools sell affordable sets of sockets which are fine for the casual user. My gun can have a wheel off in around 30 seconds, without applying any force to the vehicle, which is a very welcome thing when you have a car in a serious recovery situation with a flat tyre. That alone pays the price of entry.
    I spent a large part of the first 20 years of my 'adult' life on the spanners, and I'm paying for it now at 65. Sure, we had some air tools if we were near a shop with air, but mostly we weren't. Cordless stuff these days????? Wow, I would have loved to have them. I'd have happily broken a few sockets. Well, provided they were as cheap as they are now.
    Enjoy your gun. Take it with you in your travels. I have a car charger for mine. See if there's one for yours, or just use an inverter.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by gromit View Post
    Colin
    Shhh.... Don't give too many secrets away Colin. That $2 socket thing is amazing. I've spent some time there as well.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
