Results 1 to 10 of 22
Thread: On board air
    St Helena,Melbourne
    1.13 MB
    On board air
    Anyone have any experience with these, look like good value for the kit ?
    4WD On-board Air Compressor – Scintex Australia
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    VladTepes's Avatar
    Bracken Ridge, Qld
    No knowledge of those performance/quality wise but it does seem like good value!
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Feb 2014
    It does look like good value.
    the duty cycle and remote inlet and outlet options are good features.
    Phil B
    Custodian of:
    1974 S3 swb wagon (sold)
    1978 S3 swb canvas
    48 749 '88 4x4 Perentie
    1985 County with 4BD1T
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by Phil B View Post
    Plus the tank would give you options for inflating other items.
    1974 VW Kombi bus
    Wheelers Hill, Melbourne
    This is a pretty good comparison of compressors.
    12 volt aircompressor test - THE LONG PADDOCK
    I frequently use 2 different units, One is a permanently mounted bluetongue but the one I use mostly is an Aldi $99 job which way outperforms the bluetongue. I recently did a 3 month 22,000k trip & left the Aldi job at home as it does take up a bit of space and ended up using the bluetongue about 15 times taking the defender tyres from 25 to 36-38 psi. It is quite durable but you don't want to be in a hurry, it took about 5 minutes each tyre.
    I would say the 51 LPM quoted for the one you are looking at would be at 0 psi which should be quite reasonable.
    Personally I would buy a similar to the Aldi one and an air receiver etc & pocket the change.
    This is the closest to the Aldi one I have extensively used ( my mates usually "bot" the use of it.)
    Mean Mother Adventurer 3 Air Compressor 160L/Min
    This looks similar but less $$
    XTM Air Compressor 160LPM 150PSI | BCF
    David
    Kallangur, Brisbane
    I have had one of their compressors pumping my van suspension to 100psi for 4 years now with no problems. My van has travelled 80k km so the suspension compressor has worked reasonably hard.
    I sometimes use the van system to pump the tyres on the van & D4 so the compressor gets hammered then.
    + 2016 D4 TDV6
    350RRC's Avatar
    350RRC is offline ForumSage Silver Subscriber
    Quote Originally Posted by DeeJay View Post
    David
    I've got the Aldi one as well and it's been great.
    They usually show up at Aldi on Father's day weekend if anyone is interested.
    DL
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    I like the look of this setup and 100% duty cycle at 100psi is a lot better than most I’ve seen. Operation up to 200psi is pretty decent. I was running 120psi on my engine driven system but given I had to remove my air tank due to the Power steering box I’ve installed and that got me thinking I might use the AC compressor for actual AC at some point I’ve been thinking about a decent 12 volt system. This tank is smaller and would fit under the back somewhere no dramas.
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    David
    Good to see the ABR Sidewinder is still right up there. I’ve had one for years and it’s done plenty of work too, been around Australia twice (not with me but mates) who both used it regularly and it’s still going strong. Wouldn’t use it as a fixed unit though, will keep it portable.
    May 2012
    Wannanup WA
    4.70 MB
    The only thing that I dont like is the pressure switch. Appears that 150 on / 200 psi off is not adjustable. Yes, you will have more volume at 200 psi, but it is making the compressor work a lot harder than maybe necessary.
