Results 1 to 8 of 8
Thread: 300tdi AC Condenser
    Jan 2018
    Sandringham
    300tdi AC Condenser
    Hey Legends,
    I need a new AC condenser for my 95 defender 130, and haven't had much luck sourcing one.
    Has someone fitted one from another vehicle?
    Have been tossing up ditching the unit but if it can be done i would like to know.
    Nov 2007
    Townsville Nth Qld
    Just did mine 300 tdi last week , off the shelf item. Not sure if i still have box as aircon guy got it for me. will look in the morning.
    Jan 2018
    Sandringham
    Quote Originally Posted by Bazzle218 View Post
    Thanks Baz, do you remember how much it cost?
    Nov 2007
    Townsville Nth Qld
    Not exact price mate as im rebuilding full system with new compressor , dryer, blower motor, quoted about $1600 all up. purchased from Ashdown Ingrams. CNX413 (Sanden P/N MFC_2068AE ) Just had to drill the holes for the mounting points to 6mm
    Baz
    Mar 2012
    Australia
    Where are you getting you AC system overhauled - thinking of getting my rebuilt before next summer.
    Nov 2007
    Townsville Nth Qld
    Quote Originally Posted by jay_guess View Post
    Stripped it down myself and removed the box. cleaned evaporator and then gave it to a aircon guy to change out the tx valve. I then put it back together with new orings and will be getting it regassed in the next week or so. I did not have to worry about decanting the gas as the compressor seal had blown and non in the system. Can you remove and replace parts yourself ?? Yes you can. Baz
    Trout is offline Master Silver Subscriber
    Boonah
    Hey Baz
    Does your replacement have the same fin pitch as the old one. I have had enough of my defender running hot so I am getting a more efficient radiator. I reckon the very fine pitch of the air con condenser is a big part of of the problem. So I would be keen to see if there is a less restrictive option.
    I know everything in the cooling system has to perfect in a tdi to keep the temps under control but event then it is still marginal. I want to be able to tow my tvan on those 40 degree degree days with the air con running full bore and not having to spend the whole time with my eyes glued to the temp gauge.
    Nov 2007
    Townsville Nth Qld
    As far as i know it looks s the same as the one removed.
