Good choice. We have a 2009.
Check the gearshift for clunks, but beware it's a slow truck-like gearshift, so don't try to rush it. The six speed means you should only be doing 2000 revs at 100 kmh in 6th.
Some came out of the factory without enough grease on the output shaft and can go dry.
In some the heater valve, which is plastic, warps and let's warm coolant heat the air if the air-con is off. It's a cheap fix as its a generic Fiat Citroen part.
Water leaks are possible, particularly from the joint between the flat roof and the sloping front. The gutters can also leak if too much weight has been carried on the roof. Silicone is your friend.
I recommend you fit:
Extended seat runner rails
An extension to the door brackets so the second doors can open further.
A stay to hold the rear door open.
These are all available from The Expedition Centre in Sydney.
I also recommend a rear wheel carrier to get the weight of the spare off the rear door before it warps.
We fitted rear Airbag Man airbags to ours to level it when towing.
Plus 50 headlight bulbs make a big difference.
These are very thoroughly proven and tough vehicles, so they don't need extensive modifications. For example, it isn't necessary to lift them because they already have lots of clearance. Wider tyres don't do much and are for looks only, I reckon.
Hope that is helpful.
  Reply With Quote Originally Posted by Garethdexy
