Results 1 to 8 of 8
Thread: Eaton elocker self-locking without any warning
    in the wild New England, NSW
    I have a friend with Eaton elockers front & rear on his 130.
    He appears to have a problem with the front diff occasionally, without warning, locking.
    He has disconnected the actuating power to the front diff but the problem still occurs at about the same frequency.
    Can any experts confirm that it is possible for these to "self lock" and if this is what is occurring what possibly is the "fix"?
    It has become potentially very dangerous eg. - on a roundabout.
    All appropriate advice will be appreciated.
    Jul 2011
    Yarrawonga, Vic
    Quote Originally Posted by 87County View Post
    After looking at the video on how they work,
    I'm no expert, but what a stupid design , The diff only stays locked whilst torque is applied in one direction & unlocks when backing off, so in some situations that dog clutch is going to get hammered. A proper diff lock stays positively engaged until you unlock it, this E-locker design is prone to excessive wear and damage. I'd be pulling that diff out ASAP and replace with an ATB or Eaton TrueTrac. Very dangerous indeed could lead to a catastrophe.
    Dec 2017
    wandin nth vic
    My 20 cents worth. Seems you need power to instigate lock. Therefore if power is disconnected fault has to be within the unit.the unit seems to disengage under no load but only to the next rise in the locking pin cam . My guess. (20 cents) the return springs or wave washers are damaged.
    Jul 2011
    Yarrawonga, Vic
    Quote Originally Posted by theelms66 View Post
    Broken return spring could cause the fault for sure , especially given (not shown in the video) the engagement is by electromagnet ring dragging on the cam ring , much like a electric trailer brake. Theres always going to be friction or suction , surface tension or whatever the fluid dynamics are , especially with thicker 140 oil when cold , of the magnet ring dragging the cam ring into lock position. I can visualise that being a possibility.
    NSW SW Slopes
    IIt has become potentially very dangerous eg. - on a roundabout.
    Stay away from mountain trails with a sharp drop-off!
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    I have an elocker and had the same problem on my first centre (replaced under warranty). The return spring in the earlier built versions were not strong (firm) enough to resist the hydraulic pressure of the oil and allowed the cam to engage. Happened when hot or cold oil. While mine was not an early version it was built with the less than ideal spring. Get it replaced under warranty. Since then i’ve had no issues with engagement.
    MLD
    Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
    Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
    Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
    Gone: (Dorothy) MY99 TD5 D110
    Apr 2011
    Dungowan
    Take it this is the cause of his hard steering issue he was talking about?
    '93 D1 V8 auto
    '93 D1 200Tdi 2-door, ARB's, MD transfer, sill tanks, winch, 2"lift.......
    '95 D1 V8 auto......gone
    '86 V8 RRC.....gone
    I truly hope it's as simple as this Rick
    He's taking it to ARB on 5 Aug for a "diagnosis" that they will overcharge him for.
    I don't even have a locker but yours have towed me out of a couple of patches so I think you would know a lot more about lockers than I would.
    I personally think he'd be better off with standard diffs but it's not my motor car.
    I just think it must be hard for him, making a start in a new country where we murder our formal language, drive on the other side of the road, get ripped off by labour hire companies & car dealers, and call each other bastards. So I'm trying to do my best to help out
    I'll try to get him along to our meet up next week.
