Results 1 to 6 of 6
Thread: glow plugs
    Jan 2016
    Lane Cove
    glow plugs
    My Perentie with glass fuses does not seem to be getting power to the glow plugs .I cannot read the wiring dia .Does anybody know where the plugs get their power from and what colour the wiring is and if there is a relay involved . thanks Peter .
    Mar 2007
    Canada
    Directly from the ignition switch. There is no fuse.
    Kingston, Tassie, OZ.
    .. which also begs the question why are you needing glow plugs? Above the snow line I can understand, but in normal practice they start fine without them...
    down to minus 4 and I didnt need them.
    So near as I've been able to work out they mostly seem to be fitted for 2 reasons.
    1. hey this is cool, everyone else has them why dont we put some in?
    2. to fill the hole that you use to do a compression test.
    (ok so they help if you have a lazy battery or starter and in extreme cold (-10 or lower))
    Jan 2016
    Lane Cove
    plugs
    Quote Originally Posted by thomson View Post
    I have never needed them before but at 5 am at Orange friday morning for the 1st time it would not fire up cleanly there was deep frost everywhere , when i put a meter on the plugs there was no power going to them , when it did fire up there was a dense fog coming out of the exhaust till it started to run cleanly .
    Jan 2016
    Lane Cove
    starting
    Well it turned out that the glow plugs are not working ,but it was the lift pump that was causing the starting problems . If I gave it a couple of hand pumps it would start fine . So for 200 bucks I had the lift pump reconditioned , cut seats new springs valves etc and we are back to starting fine again. Glad it did it on the last day ofP1010015.jpgP1010027.jpgP1010015.jpg a 9000 k 2 month trip
