Results 1 to 10 of 11
Thread: 6x6 4th gear?
    Oct 2011
    Burra NSW
    6x6 4th gear?
    Hi all,
    Ive just put a new master and slave cylinder in the 6x6, all gears bar 4th select fine, 4th won't select at all.
    No weird noises or grinding, it just simply won't go into the 4th gear position?
    All other gears working fine..any thoughts?
    clutch drag and the syncros on the 4th selector are no longer doing the grip part of syncro magic so the block part is working baulking you until the align bit (which doesnt happen without grip) happens.
    bet I can double shuffle it in
    OR..
    youve moved the box and the foam is blocking the shift lever.
    Oct 2011
    Burra NSW
    Thanks mate, no amount of double clutching will get it in..been trying
    Aug 2010
    Sunbury, VIC
    The LT95 in my 101 won’t select 4th until it’s warmed up a bit - PO used gear oil in it so my guess is the oil pump gear is stripped so until things get a bit sloppy it’s a no go - or it has the issue BK stated, I’ve never got to the bottom of it but that’s the same, can’t shuffle it in with matching revs, etc until it wants to. I keep meaning to swap it out with the spare box I’ve got but I’ve learned to live with it and once I’ve driven it a few KM it’s fine for the rest of the day. 😁
    Have you tried taking it for a drive until things warm up a bit?
    Jan 2016
    Lane Cove
    gear box
    Quote Originally Posted by Homestar View Post
    can you put it in without the motor running ?
    Aug 2010
    Sunbury, VIC
    Never tried to be honest but probably. Just put up with it - it’s been like that for 5 years and never really bothered me. 😁
    Oct 2011
    Burra NSW
    I took it for a longer drive and managed to get it in, but when I tried again it was still as stubborn as before..Wont go in with motor off either.
    Its a pain in the backside the way it is!
    Hay Point
    Quote Originally Posted by Summiitt View Post
    Hi all,
    Most likely a selector adjustment problem.
    Cheers......Brian
    1985 110 V8 County
    Oct 2011
    Burra NSW
    Quote Originally Posted by Bearman View Post
    Im just wondering if its a collapsed bearing? 4th gear has had a slight bearing whine for some time?
    Jan 2016
    Lane Cove
    gear box
    What is the process of adjusting the selectors ??
